Body mount rust issues - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Body mount rust issues
Nitro Gear Packages Now Available at Rockridge 4wdJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFThe ULTIMATE "Selectable" Locker System! Brough
Unread 10-03-2014, 06:48 PM   #1
YJRoller
Hey all,,
I have a rust issue and was wondering how everyone else deals with this.
We took it for inspection and was told that the 2 body mounts under the door(s) was too bad.
These are the mounts in the "center" of the frame,, like I said the one right under the door.
Is there a "patch" kit available where I can cut the bad metal out and weld the new in? I am pretty sure quite a few members here have had this identical problem.
This is my wifes ride by the way,, It's a 1998 TJ and she is pretty partial to it.
Heck,,, if someone lives near Carlisle/Harrisburg I would pay someone to fix it right.
Thanks in advance for any help
Jeep, The name says it all
1998 TJ ROR lifted and lots of other goodies
1996 2 DOOR 2.5, 5 Speed Cherokee, 6.5" lift rolln on
33"Swampers. Lots of extras
YJRoller is offline   Reply With Quote Quick reply to this message
Unread 10-03-2014, 09:16 PM   #2
JealousDad
The part is called a "torque box" and these guys sell them;
http://www.classicent.com/jeep/ (scroll down to see them)
It sounds like they are well made and the company has tech support for install instructions. Good luck!
JealousDad is offline   Reply With Quote Quick reply to this message
Unread 10-03-2014, 09:37 PM   #3
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Is the rest of the tub solid?
Check it out well. You might be better off replacing the entire tub.
Wheelin98TJ is offline   Reply With Quote Quick reply to this message
Unread 10-03-2014, 10:50 PM   #4
YJRoller
YES !!!
This is exactly what I was searching for. I thank you for the information.
Unread 10-03-2014, 10:52 PM   #5
YJRoller
For a 16+ year old Jeep the tub is in pretty decent shape.
I actually did have a contingency plan for swapping the entire tub if I could not locate the "parts to replace the rust damaged areas.
I thank you for your reply,,,
Unread 10-03-2014, 11:00 PM   #6
JealousDad
No problem! I haven't seen much about the install so maybe you could do a thread about it if you decide to use them.
Unread 10-05-2014, 09:05 PM   #7
Trespasser
Ive got the same issue. My shop let it pass but basically told me they would fail me for this next year.
On the website it says "Attachment reinforcements and nuts are attached for your convenience. You may order in standard steel for welding into place or order in galvanized steel for riveting or screwing into place."
Has anyone attempted attatching this panel with screws??? Thats intruiging to me because I cant weld.
Trespasser is offline   Reply With Quote Quick reply to this message
Unread 10-06-2014, 05:05 AM   #8
26679cj5
Hi. I installed the full set on my TJ over the winter. I had originally planned on welding them in,but I ended up going with 1/4" aircraft grade stainless steel Magna-loc rivets by Huck Fasteners.The rivet gun can be purchased from harbor freight for about $75 or so. I do have several pics of the process, but don't have them uploaded yet.
26679cj5 is offline   Reply With Quote Quick reply to this message
Unread 10-06-2014, 11:57 AM   #9
jeepwrangler97
I cut mine out & made some new channel with a nut welded inside it. I'll get some pics up later.
jeepwrangler97 is offline   Reply With Quote Quick reply to this message
