body mount bolt ?? - JeepForum.com
post #1 of 3 Old 02-12-2005, 12:45 PM Thread Starter
superman613
body mount bolt ??
While attempting to take off my body mount bolts i snapped one. It's on the driver's side, the middle one of the three. So i have two questions. What's the best way to get it out... and will i be okay driving without it?
TIA
Tommy T
'98 Wrangler SE (yea that's right, four-banger)
5 speed tranny
33x12.50R15 MT/R's
15x8 Cragar Soft 8's
Explorer ProComp 2" suspension lift
1.75" BB lift on top of that
BL/MML coming soon to a Jeep near you!!
White Jeep Member #613
superman613 is offline
post #2 of 3 Old 02-14-2005, 08:15 AM
What The?
I broke the same one. The best solution is to drill it out, tap some threads, and put a new bolt in. But, since it's just one, you'll probably be fine without it. I'd at least try to slip the puck in, just so the body has it to rest on.
Joe
What The? is offline
post #3 of 3 Old 02-14-2005, 10:16 AM
chadjeep
if you could, you could weld a head on to it and just take it out, it wouldn't take much, you should be fine, but I would address the problem as soon as possible to prevent other problems.
chadjeep is offline
Broken Body Mount Bolt 05RedRME TJ Wrangler Technical Forum 16 06-28-2015 07:20 PM
Broken body mount bolt CalicoYJ YJ Wrangler Technical Forum 8 10-28-2010 07:22 PM
Broken Body Mount Bolt matthewh_1 TJ Wrangler Technical Forum 3 10-27-2009 09:10 PM
Body mount bolt problems Rubicon_Rob04 TJ Wrangler Technical Forum 2 04-20-2009 05:27 PM
'01 stripped body mount bolt Dans1tj TJ Wrangler Technical Forum 5 11-14-2006 09:53 PM
