Quantcast body and motor mount lift causing t-case problems - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > body and motor mount lift causing t-case problems
Old 01-16-2009, 02:28 PM   #1
JeepDoo
i recently installed the JKS body lift/motor mount lift combo. I tried to put it in 4wd earlier and the thing isnt going in. The guy at the 4wp store said it is because i have an aftermarket t-case shift bracket, and something about there not being enough leverage to shift it in gear.
The reason i have that aftermarket bracket is because my stupid cousin installed a t-case lowering kit back when he had the jeep, so i guess he put that bracket in there too. The 4wp guy said i need to get a stock bracket.
Any suggestions on how to fix the one i have? i dont even know what the stock bracket looks like, so if somebody has a pic that would be great so i could compare it to mine.
PLEASE HELP because my buddies with jeeps and i are going on an offroading trip this weekend, i need a fix asap.
Hey hey, my my. Rock and roll will never die. - Neil Young
We've got too many gangsters doin dirty deeds. Too much corruption and crime in the street. It's time the long arm of the law put a few more in the ground. Send them all to their maker and he'll settle them down. - Toby Keith & Willie Nelson
[URL="http://www.norcaljeepers.net/forum/"][FONT="Century Gothic"][B][COLOR="DarkSlateGray"]NOR CAL JEEPERS FORUM[/COLOR][/B][/FONT][/URL]
[URL="http://www.jeepforum.com/forum/f20/sound-system-upgrades-speakers-amps-what-you-need-know-964324/"]Want to hear the music in your TJ, look no further...[/URL]
[SIZE="4"][COLOR="White"][B]Longboard Drunk, Jeep Naked, Ski Powder[/B][/COLOR][/SIZE]
[COLOR="LemonChiffon"][SIZE="1"]and finish calculus homework[/SIZE][/COLOR]
JeepDoo is offline   Reply With Quote
Old 01-16-2009, 02:35 PM   #2
LandoCommando
Something is screwy with your linkage.
Get under there and watch it as someone shifts between 2hi to 4lo.
Something may be loose or broken or just out of measure.
Signatures are for attention whores.
Oh the irony.
LandoCommando is offline   Reply With Quote
Old 01-16-2009, 02:39 PM   #3
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Even if the drop bracket was installed it shouldn't make that much difference to shift with the MML.
Stock bracket.
http://www.4x4xplor.com/images/PA-BL/BL-11.jpg
drop bracket.
You might just need to adjust the shift linkage.
TheBoogieman is offline   Reply With Quote
Old 01-16-2009, 02:49 PM   #4
Dirticus
The shift linkage has a bolt that pinches a rod that then moves the shift lever on the t-case, at least it does stock. With angle and distance changes this may need to be adjusted. Let it loose so that the shift handle settles all the way down then tighten it. Hope that helps. If you don't get it right before your trip just reach in there before the trail and man instruct that thing into 4lo and go.
Dirticus is offline   Reply With Quote
Old 01-16-2009, 04:26 PM   #5
JeepDoo
Thats what the 4wp guy told me to do, hopefully i wont be sitting in a mud puddle when i need to shift
thanks for the help, ill screw around with it when i get off work, ITS FRIDAY
Glock Forum
