Body lifts/Suspension lifts - JeepForum.com
post #1 of 5 Old 11-18-2006, 02:45 PM Thread Starter
OffRoadin'Lover
does anyone have pictures they can show that shows the difference between these two?? and explain thanks
97 Tj, 4 banger
Brush Guard, Off Road Lights
3 inch body lift, With 33s
Mods to come-4.56 gears or 4.88, NEW Bfg 33s,2.25 BB lift
OffRoadin'Lover is offline
post #2 of 5 Old 11-18-2006, 02:48 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
No pictures necessary... it's pretty simple.
A body lift consists of spacers inserted between the frame and body to lift the body up an inch or two up off the frame. It only gives more tire clearance but it does not increase the ground clearance of anything else underneath the Jeep.
A suspension lift consists of either taller springs or a spacer placed on top of the factory springs. Most suspension lifts include more items than just springs including but not limited to new control arms, trackbars, etc. A suspension lift is more expensive and more difficult to install but this is the type of lift you want for better offroad worthiness of a vehicle. It lifts everything except for the axles, only bigger tires can lift the axles.
Getting
Jerry Bransford is offline
post #3 of 5 Old 11-18-2006, 02:56 PM
Rocky529
Rocky529's Avatar
Here is a 1.75" suspension lift:
Here is a 2.25" suspension lift and a 1" body lift. Note the gap in the rear wheel wells:
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #4 of 5 Old 11-18-2006, 02:56 PM Thread Starter
OffRoadin'Lover
thanks man ,thanks for clearing that up
97 Tj, 4 banger
post #5 of 5 Old 11-18-2006, 02:57 PM Thread Starter
OffRoadin'Lover
Thanks guys
97 Tj, 4 banger
Newbie questions (body lift, suspension lifts and lockers) GoldenP51 TJ Wrangler Technical Forum 9 08-12-2009 12:43 PM
What is the best.... (suspension lifts and body lifts) RjAndJeep TJ Wrangler Technical Forum 24 06-03-2009 09:33 PM
A run down on suspension lifts.body lifts.spacers mightydog78 TJ Wrangler Technical Forum 5 02-28-2009 12:21 AM
Suspension Lift vs. Body Lifts...? PDX-TJ TJ Wrangler Technical Forum 3 08-02-2006 01:28 PM
Warranty and Lifts? Body or Suspension Taz728 TJ Wrangler Technical Forum 3 07-23-2002 11:01 PM
