Body lift vs hockey pucks - JeepForum.com
View Poll Results: spacers or pucks
spacers 81 59.56%
hockey pucks 55 40.44%
Voters: 136. You may not vote on this poll
 1Likes
post #1 of 113 Old 10-09-2008, 01:51 PM Thread Starter
jimaug87
I'm putting a susp lift in my Jeep soon. I'll be putting a 1"mml in to avoid a tcase drop.
So with the mml I'm going to put in a 1" bl as well. I am shopping for a body lift kit that only includes the spacers and bolts. I am having a tough time finding just that. I don't want to pay for a t-case relocator and maybe a radiator drop. Does anyone know a place that has spacers and bolts?
I would like to go the cheap route with hockey pucks and grade 8's from lowe's. Does the hockey puck lift have any negatives? I don't want to do that just to put in spacers because the hockey pucks are falling apart or watever.
2005, I6, 6 Speed, RC 2.5", RC front adj. track bar, 31" Goodyear DuraTracs
"Nobody is comepletly useless. We can always serve as a bad example."
jimaug87 is offline
post #2 of 113 Old 10-09-2008, 01:58 PM
SKIBUMM
Same question here but I am thinking of Skateboard wheels instead of hocky pucks but would l like to know of the negatives if any of both.
SKIBUMM is offline
post #3 of 113 Old 10-09-2008, 02:02 PM
BlackBellamy
BlackBellamy's Avatar
use skateboard wheels instead - hockey pucks aren't durable imo
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline
post #4 of 113 Old 10-09-2008, 02:05 PM
Jay98TJ
Jay98TJ is offline
post #5 of 113 Old 10-09-2008, 02:09 PM Thread Starter
jimaug87
ahhh skateboard wheels. Use the poll option 'hockey pucks' for either.
Any reason not to get a cool color skateboard wheel? Are skateboard wheels 1" wide? When I do my 1" mml I want everything to line up.
jimaug87 is offline
post #6 of 113 Old 10-09-2008, 02:11 PM
Squeeky
Get an actual body lift..they aren't that expensive and in most cases they come with everything you need including grade 8 hardware.
Originally Posted by Unscathed View Post
Yea.. I mean really... who herculines their jeep naked.. go figure..
Squeeky is offline
post #7 of 113 Old 10-09-2008, 02:25 PM
lilboy1023
I did a performance accessories body lift. I got mine from 4wd.com or 4wheelparts.com. I did a 2" and it came with everything that I needed.
lilboy1023 is offline
post #8 of 113 Old 10-09-2008, 02:32 PM
TheBoogieman
Dead Jeepers Club
TheBoogieman's Avatar
Hockey pucks are for hockey.Spend $100 for a Performance Accessories BL.Don't be cheap.
TheBoogieman is offline
post #9 of 113 Old 10-09-2008, 02:41 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Providing you use Grade 5 bolts, I see nothing wrong with using hockey pucks. No need for the added expense of Grade 8 bolts for body mounts.
Jerry Bransford is online now
post #10 of 113 Old 10-09-2008, 03:36 PM
Steelman
IX-X-XIII-XIV-XL-XLIII
Steelman's Avatar
Did you use Hockey pucks Jerry?!
Check out the body lift from Currie Enterprises. That's the one I used. Billit Aluminum pucks (powder coated black) and bolts only...no relocator kit.
-Bob
'98 Black TJ Sport 4.0L/Auto Trans
-(O|||||||O)-
my rig:
_____________________________________________
Originally Posted by _Trucker View Post
I would rather shoot you in the face than play a guessing game....
Originally Posted by mrblaine
Are you bipolar, passive agressive, or just unable to recognize the dichotomy of your thought processes?
Steelman is offline
post #11 of 113 Old 10-09-2008, 03:43 PM
Jerry Bransford
Administrator
No but I used hockey pucks for a couple of my bump stops. Structurally, they're not much different than the pucks my PA body lift comes with. They even weigh about the same. Hockey pucks probably take more abuse in a youth hockey league game than they ever do as body mount spacers.
post #12 of 113 Old 10-09-2008, 04:20 PM
imbezol
imbezol's Avatar
I agree with Jerry on this one. I just installed bump stop extensions using hockey pucks, and I also just installed a JKS 1 1/4" BL on a friend's Jeep. I think hockey pucks would be perfectly fine for a body lift. They're about $1 each tops and you can pick up all the grade 5 or 8 hardware you need for under $5. It's a pretty cheap way to get an inch of lift! The only thing I can see is you get nice instructions with the JKS on how to raise your radiator an inch but if you just take a look and drill the holes it's pretty straight forward. Also, the transfer case shifter relocation bracket probably isn't strictly needed with only 1". If shifting the transfer case is a little sticky after you could probably make the bracket JKS gives you in about 5 minutes out a scrap piece of your stock front bumper.
imbezol is offline
post #13 of 113 Old 10-09-2008, 04:23 PM
Steelman
Steelman's Avatar
I'm asking this because I don't know:
Any idea how the hockey puck material holds up to the weather, sun, salt, etc.?
-Bob
-(O|||||||O)-
my rig:
Steelman is offline
post #14 of 113 Old 10-09-2008, 04:26 PM
Jerry Bransford
Administrator
If hockey pucks can hold up to being frozen, smashed, slap-shot, slammed into teeth, plexiglass, steel hockey skate blades, hockey sticks, etc., they'll probably hold up fine to a little sunlight, salt, cold/hot weather, etc.
post #15 of 113 Old 10-09-2008, 04:36 PM
Steelman
Steelman's Avatar
If you say so, but I feel differently. How long is a hockey puck used on the ice compared to sitting under someone's Jeep for a few years?
A wise man once said, "Do it right, or not at all"!
-Bob
-(O|||||||O)-
my rig:
Steelman is offline
using hockey pucks for body lift??? bigV TJ Wrangler Technical Forum 36 04-16-2007 03:49 PM
were the heck do i buy hockey pucks?? alex71 TJ Wrangler Technical Forum 15 05-13-2006 01:22 PM
T-case drop with a hockey pucks? 02tjsport TJ Wrangler Technical Forum 3 04-30-2006 08:31 PM
anyone here use hockey pucks for your body lift? rsoffar YJ Wrangler Technical Forum 7 11-20-2005 07:00 AM
hockey pucks asjeep TJ Wrangler Technical Forum 9 06-27-2003 09:49 AM
