Body lift VS. Budget Boost - JeepForum.com
post #1 of 49 Old 01-14-2007, 02:49 PM Thread Starter
jake7893
I'm not sure what I should do yet. I just got big tires, and I'm ready to spend more money now. I want to get either a 1-2'' body lift or a 1.5-2.25 budget boost. I've seen some good prices on the budget boost. I need some opinions and pros and cons. I don't know what I want to do yet. If any of you know of any good deals going on or anything it would be greatly appreciated.
WARNING**
ALL RESPONSES BY THIS USER ARE KNOWN TO CAUSE CANCER (ONLY BY THE STATE OF CALIFORNIA)
WARNING**
jake7893 is offline
post #2 of 49 Old 01-14-2007, 02:52 PM
mic6
if you got 31s as I see in your signature then you will be fine with a BB. Go with the RE BB and you will be happy. A Body lift is good for additional lift not as your primar lift. If you go with BB now you can add a body lift later and fit 33s! Hope that helps.
mic6 is offline
post #3 of 49 Old 01-14-2007, 02:56 PM
SecondTJ
SecondTJ's Avatar
Go for the 2" BB. More ground clearance, better flex, cheap, easy.
You can always add a 1" BL later if you want to goto 32s.
You wont gain any ground clearance or flex with a BL
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #4 of 49 Old 01-14-2007, 02:59 PM
nicolas-eric
a BB gives you better offroad capabilities. a BL only makes more space for bigger tires.
i have both for my 32s, a 2" BB and a 2" BL.
4" OME & 1" Spacer & LT Shocks 2" BL 1" MML JKS Discos JKS Rear Links OME Steering Stabilizer
35x12.5x15 Cooper STT @ 8.5x15 ARB Airlockers ARB Diff Covers 4.56 Gears SS Brake Lines
Warn Skids Genright Rock Slider Smittybilt Rock Crawler Rear Bumper Safari Snorkel OBA
12.000 lbs Winch Synthetic Winch Line 4x 130W Hellas 4x 200W Hellas @ Lightbar E-Fan
nicolas-eric is offline
post #5 of 49 Old 01-14-2007, 03:12 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
i have both on mine as well, a 4" suspension lift and a 2" BL, a BL only raises body, there for gaining tire space and keeping COG rather low, a 2" BB raises frame and all, raising COG more then a BL, gaining ground clerence for everything, a BB is the better choice even though it is cheaper
RnEmOvr is offline
post #6 of 49 Old 01-14-2007, 04:21 PM
McLovin
Budget Boost now then body lift when you want bigger tires or a flat skid.
I have 4 new zone hydro shocks for sale...PM for a price.
McLovin is offline
post #7 of 49 Old 08-16-2009, 08:27 AM
Myles1980
hey guys...
am currently with a 2" Tflex BB with 31;s. Want to get it up to 33's but not sure if the suspension lift is worth it. Theres a shop by my house with a 4"suspension lift package for 1350 but not sure if the 4" is overkill. I only have a 4 cylinder so wont need to regear until i get larger tires. You think 3" suspension is enough?
any recommendations as far as brand? OME, RE, Skyjacker?
Thanks
Myles1980 is offline
post #8 of 49 Old 08-16-2009, 08:35 AM
squigy123
go with a max of 1.5" body lift and skip the budget boost if you ever plan on doing other suspension changes. Because for a lot of things you will need the body lift and the BB would just be tossed aside later if you do a better suspension lift.
squigy123 is offline
post #9 of 49 Old 08-16-2009, 08:37 AM
squigy123
Originally Posted by Myles1980 View Post
hey guys...
Thanks
Put an 1.25" body lift on it from RC and put the tires on. the body lift is needed for other mods anyway.
i run a 2.5 suspension and 1.25 body lift and 33s are perfect for that application. you would be ok with just the 2" suspension and body lift.
post #10 of 49 Old 08-16-2009, 08:39 AM
MudDuck99
2014 JK Wrangler
I'D GO WITH THE budget boost first then if you want more clearance and a body lift. This site has some pretty cheap Bb's: www.1sourcemfg.com
MudDuck99 is offline
post #11 of 49 Old 08-16-2009, 08:49 AM
Myles1980
ok so ill def take the BB out when i size up. what do you think a 3" suspension and 1.25 BL will run? around 1100 installed?
post #12 of 49 Old 08-16-2009, 09:08 AM
cmgorman94
You only need about three inches of lift to comfortably fit 33s. Leave the budget boost on and just install a 1-1.25" BL. That will give you just the right amount of lift for 33s. No need to change your suspension just yet, and this way will be a lot cheaper. Take the money you saved by not changing the suspension and put it towards gears.
cmgorman94 is offline
post #13 of 49 Old 08-16-2009, 10:25 AM
ArchStanton
Speaking of a BB, who makes the best quality BB? They can't all be the same. I was thinking about Daystar or Energy Systems. I want to stick with an American made product. I'm also planning on keeping my stock gas-charged shocks. I like the factory ride. I'd appreciate any comments.
ArchStanton is offline
post #14 of 49 Old 08-16-2009, 10:36 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
They ARE all the same.Spacers are spacers.It's the quality of the shocks that determine how it rides.Skyjacker hydro shocks for $145 shipped are the best,least expensive shock that rides great.BDS 5500 and OME are next and more expensive.To me, a Jeep always rides like a Jeep so why waste the extra money on OME shocks.
TheBoogieman is offline
post #15 of 49 Old 08-16-2009, 10:49 AM
Myles1980
thanks for the info. but with the spacers and a BL, whats the likely hood of having problems with offroading? is there a chance of the spacers slipping out or getting out of align?
What's the difference between a Budget Boost and a Body Lift staquinas TJ Wrangler Technical Forum 26 08-06-2009 01:14 AM
Jeep (budget boost or body lift) JCWrestler TJ Wrangler Technical Forum 14 07-02-2008 05:20 PM
Budget Boost and Body Lift question rooster5333 JK Wrangler Technical Forum 5 10-28-2007 03:11 PM
body lift or budget boost RON310 TJ Wrangler Technical Forum 15 10-17-2007 09:29 PM
Budget Boost & Body Lift Bad Idea? DesertTJ TJ Wrangler Technical Forum 17 02-24-2007 05:25 AM
