Body lift removal question - JeepForum.com
post #1 of 14 Old 02-12-2013, 02:37 PM Thread Starter
TJcowfan
Hey guys, I've got my TJ that has a 3" body lift on it and I just don't like the way it looks so I want to remove it and bring it back to stock size. Now my question is if what I have on there is the stock body kit with just 3" spacers on top. If so, can I just remove the spacer and call it a day or do I need anything more than just new nuts and bolts? This is a pic of what the current body lift looks like. Thanks!
TJcowfan is offline
post #2 of 14 Old 02-12-2013, 02:41 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
1. Remove body lift spacers
2. Replace bolts with factory length bolts (shown below in post #3)
3. Remove radiator fan shroud drop
4. Remove gas tank filler hose extension (or make sure hose does not kink when you lower body down)
5. Remove steering column shaft support
6. Remove bracket from t-case shifter linkage
Wheelin98TJ is offline
post #3 of 14 Old 02-12-2013, 02:42 PM
Wheelin98TJ
JEEP FREAK
Factory bolt sizes:
post #4 of 14 Old 02-12-2013, 03:49 PM Thread Starter
TJcowfan
So the pucks that are under that spacer is the O.E.M body mounts? I don't need to go out and buy a new set or anything else but the bolts?
TJcowfan is offline
post #5 of 14 Old 02-12-2013, 04:45 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
That is correct, you can even trim them down to 1.25`` or 1`` for a smaller bl if you so choose
Sent from my tablet, so expect errors.
RnEmOvr is offline
post #6 of 14 Old 02-12-2013, 04:53 PM Thread Starter
TJcowfan
Awesome! Thanks!
TJcowfan is offline
post #7 of 14 Old 02-12-2013, 04:57 PM
Jt_grooms
I have the factory stock bolts you can have just pay shipping! If you want them
BamaJeep828
Jt_grooms is offline
post #8 of 14 Old 02-12-2013, 05:03 PM Thread Starter
TJcowfan
All 11? How much? 20109
TJcowfan is offline
post #9 of 14 Old 02-12-2013, 05:20 PM
Jt_grooms
Yeah all 11. Ill check and see how much shipping is in the next day or two
BamaJeep828
post #10 of 14 Old 02-12-2013, 05:25 PM Thread Starter
TJcowfan
Alright sounds good. PM me pics if you could
TJcowfan is offline
post #11 of 14 Old 02-12-2013, 05:29 PM
sjones26573
If you decide to keep 1-1.25" (which you should if you ever plan on doing a TT), you can't use the stock bolts.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #12 of 14 Old 02-12-2013, 05:42 PM Thread Starter
TJcowfan
What's a TT? And I'd keep the the body lift once I take it off and just get the bolts I need if I do decide to just go smaller. For now I just want back to stock body size.
TJcowfan is offline
post #13 of 14 Old 02-12-2013, 05:43 PM
sjones26573
Tummy tuck. Flatter transmission skid.
Jeep-Owner.com
post #14 of 14 Old 02-13-2013, 07:05 PM
Jt_grooms
Here's the bolts! I know it's more than 11 but this is what I got off a guy. I needed stock bolts so this is what he sent. I put on 1.25" BL
BamaJeep828
