Body lift question..... - JeepForum.com
post #1 of 7 Old 07-11-2010, 06:34 PM Thread Starter
zachjf
Body lift question..... *updated*
I installed what i assumed to be a Daystar 1" body lift a year ago but with the recent threads and picture regarding body lift heights I'm starting to think I may have ended up with more than I wanted.
My question is, does anyone know off hand the thickness of the stock body mounts or could someone with a true 1" BL measure their frame to body gap so I can verify what I actually have? The gap annoys me to no end and I want to fix it asap. Thanks!
Needs parts?
PM
or
zachjf is offline
post #2 of 7 Old 07-11-2010, 08:52 PM
JealousDad
I measured the stock mounts at the back of my jeep and they are 3/4" tall. You must have a 1 1/4" lift.
How do you like the Daystar lift? I was thinking of getting the same lift soon.
JealousDad is offline
post #3 of 7 Old 07-11-2010, 09:59 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
that looks like it has a rocker guard sitting on top of your body mount.
Mail crawling.
MisfitSeven is offline
post #4 of 7 Old 07-12-2010, 12:11 AM Thread Starter
zachjf
After looking at it and scratching my head I'm just going to raise the rear bumper I'm building to compensate for the BL and cover a big chunk of the gap if not all of it.
Jealousdad; thanks for the measurement! I am very satisfied with the body lift as I never liked the "puck under the stock body mount" configuration and prefer the one piece style BL's, thats just my opinion tho. The kit went on super easy and was complete with everything I needed including extra bolts and washers. I have no experience with the transfer case shifter bracket lowering piece tho as I bought an AdvanceAdapters transfer case relocation bracket to get rid of the stock setup.
Misfit; Not sure what you mean, the gold colored piece on top of the mount is a washer that came with the kit and every one of the mounts has one.
Needs parts?
PM
or
zachjf is offline
post #5 of 7 Old 07-12-2010, 05:47 AM
MisfitSeven
MAiL Crawler.
let me reassure you, you have a 1" body lift.
the tub has dimples for the body pucks to sit against. it looks like you have rocker guards, and the pucks are not sitting in the divots.
if you are building a swing out tire carrier bumper, dont worry about lifting it to cover the gap. the swing out will cover it.
if you are not building a swing out, dont raise it too much. it is there to keep you safe if you get rear ended.
Mail crawling.
post #6 of 7 Old 07-12-2010, 09:02 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
My brother had a gap guard made for his by a welding shop.
TheBoogieman is offline
post #7 of 7 Old 07-12-2010, 12:28 PM Thread Starter
zachjf
Nope, no rocker guards and I did check to make sure the mounts were sitting in the divots properly. I am building a swing out tire carrier for the bumper but I still flipped the lower brackets over a bit to see what it would look like and it raised the bumper up a 1/2" so I think I'll go with that and let the swing out cover the rest.
Thats a good idea your bro had Boogie, covers the gap up and finishes it off nicely!
Needs parts?
PM
or
zachjf is offline
Body lift , height , actual measurment , stock body mount
Tryin to figure out how I'm running 33's. Lift or body lift question. dm33buckeyes TJ Wrangler Technical Forum 21 08-14-2011 05:06 PM
body lift or suspension lift, no this isnt a stupid question!! lumpster TJ Wrangler Technical Forum 5 05-11-2009 10:19 PM
Another Body Lift and Spring Lift question KnightofMopar YJ Wrangler Technical Forum 11 03-10-2009 12:48 PM
body lift question Exhale YJ Wrangler Technical Forum 20 02-21-2007 02:21 AM
Question about body lift goo1134 TJ Wrangler Technical Forum 6 05-18-2005 05:57 PM
