To Body Lift or to not? - JeepForum.com
post #1 of 47 Old 06-19-2012, 03:18 PM Thread Starter
Blakecognata6
So i recently installed my Rough Country 4 inch x-series lift. I'm running 35x12.50x15 inch tires which is clearly fine with every day driving but i don't have a ton of clearance in the back. Its obvious by looking at it that im not going to perform well on trails.
My question is would a one inch body lift be a bad purchase? and if i were to get one what other modifications would i have to make.
Blakecognata6 is offline
post #2 of 47 Old 06-19-2012, 03:21 PM
Ironhead
have you cycled your suspension? that will tell you if its needed or not.
i am pro BL for later upgrades like tummy tuck and to raise the gas tank.
only other mods would be some work on the TC linkage and i would recommend a motor mount lift at the same time
Ironhead is offline
post #3 of 47 Old 06-19-2012, 03:26 PM
NBMgreg
mine had a 3" body lift and nothing else when i bought it. Completely ridiculous. I chopped that lift in half, and am happy with it. I do plan to do a tummy/tank tuck in the future so it is needed.
it's an easy, cheap way to get a bit of wheel clearance. I'd say go for it. Or look into tube fenders. As stated above, depending on how big you go, you'll prob need to do some mods to the gas tank filler tube, transfer case linkage, etc. Mine even had a steering shaft block, and radiator shroud lowering brackets. these were removed when i down graded though.
NBMgreg is offline
post #4 of 47 Old 06-19-2012, 04:04 PM Thread Starter
Blakecognata6
I actually did purchase metalcloak tube fenders so I'm not particularly worried about the front.. It's just my rear tires I'm concerned about but thank you for the advice
post #5 of 47 Old 06-19-2012, 04:09 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Most people use a 1.25" BL.
TheBoogieman is offline
post #6 of 47 Old 06-19-2012, 04:11 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
2015 JK Wrangler
Why rediculous?
My newest build:
Necromancer_tat is offline
post #7 of 47 Old 06-19-2012, 04:42 PM
_KONG_
Originally Posted by Necromancer_tat View Post
Why rediculous?
When it comes to cosmetics theres no right or wrong. Unfortunately for you most people think a 3" bl looks ugly. Whether or not that hurts your feelings is a different matter
_KONG_ is offline
post #8 of 47 Old 06-19-2012, 05:19 PM
Necromancer_tat
2015 JK Wrangler
It doesn't hurt my feelings that other folks think 3" body lifts look ugly. I think they look ugly myself. Bang for the buck however they're hard to beat, they work well, and if used correctly they can save people about $500...
My newest build:
post #9 of 47 Old 06-19-2012, 05:28 PM
_KONG_
Well looks aside you can argue functionality. But if your only basis is cost, its not a very strong argument for body lifts. Ill let someone more knowledgable then me explain why they may or may not be good. But on looks alone i would never consider a 3"
_KONG_ is offline
post #10 of 47 Old 06-19-2012, 05:55 PM
Ironhead
because with that much of a BL, you risk damaging your actual mount points. its like using a bigger wrench over a smaller one, you get more torque from the bigger one
Ironhead is offline
post #11 of 47 Old 06-19-2012, 05:56 PM
Necromancer_tat
2015 JK Wrangler
I run a 3" body lift on my TJ and a lot of folks don't even realize it's there... I pretty much point my Jeep where I want to go and it just goes there... it doesn't care that it's running a 3" BL... the only people who have ever cared were folks that couldn't even follow me through obstacles that I wheeled right on through without any issues.
My newest build:
post #12 of 47 Old 06-19-2012, 05:58 PM
Necromancer_tat
2015 JK Wrangler
I agree that longer body mount bolts exert more side loads.
My newest build:
post #13 of 47 Old 06-19-2012, 06:02 PM
Imped
Imped's Avatar
The day I can't point out a 3" body lift from a block away is the day I'm blind.
OlllllllO
IndyORV
Imped is online now
post #14 of 47 Old 06-19-2012, 06:08 PM
Necromancer_tat
2015 JK Wrangler
My BL isn't instantly noticable, my front and rear bumpers are designed to hide it for the most part. I can say that the difference between 1.25" and 3" off road is less than most people would think.
My newest build:
post #15 of 47 Old 06-19-2012, 06:24 PM
NBMgreg
When mine had the 3" body lift, you could see daylight between the frame and tub all the way through... it looked silly as hell from a side view. Next time you drive by a big glass building check out your reflection.
as far as performance, a body lift gains slight wheel clearances, you gain zero ground clearance. so saying the body lift helped you through obstacles is very hard to believe. Not hating on you or your rig, just stating what I feel.
and as stated above, with that much BL you are putting a lot of strain on those mounts at any type of angle.
NBMgreg is offline
body lift , modifications , susepnsion lift
Cutting body lift spacers ? How long are 1 inch body lift bolts ? MAYNARDZ71 TJ Wrangler Technical Forum 13 11-12-2012 11:33 AM
Stock body mount replacment with 1in body lift: poly vs rubber shabakand YJ Wrangler Technical Forum 2 09-12-2011 10:20 PM
Body mounts spinning 3 icnh body lift plmqazed YJ Wrangler Technical Forum 3 07-22-2011 10:57 PM
Rough country body lift vs zone body lift BadKarma1701 TJ Wrangler Technical Forum 5 01-24-2011 09:53 PM
to body lift or not to body lift? atlas trouble twistedtj TJ Wrangler Technical Forum 9 08-21-2003 12:35 AM
