Body Lift and Motor mount lift questions
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | GR8TOPS Introduces the Exogate HD Tire Carrier | The Original 3/8" Ruffstuff Diff Cover! |
#1 | |
Junior Member
I have a 1997 TJ with a 4cly, 5spd, and 4:10 gears, I recently installed the RC 2.5 lift. When I did the lift I went ahead and installed the transfer case drop that came with the kit. I have been thinking about gettin a 1" BL and a 1" MML. So for all of you that have a TC drop, BL, and MML - Do the TC and Trans shifters get bound up? If they do what is a good way to fix it?
#2 |
Drink Oregon Craft Beer!
Location: where I wheel: N 45º 36.663' W 123º 20.935', Oregon
Did you drive the Jeep before installing the xfercase drop? There's a slight probability you didn't have vibes.
1998 TJ Moss Green Sahara w/ numerous scratches & dents whose playground is on a tropical island that's 33 miles long and 4-12 miles wide, in year-round 82 degree weather. [Edit] "Now jeepin in Oregon" [/Edit] |
#3 |
Corporate Whore
My body lift came with a relocation bracket for the shifter linkage. you might even be able to remove your t-case drop if you do the mml.
It much easier to relocate the fan shroud than do a mml & my bl kit came with relocation brackets for that as well. But if you want to reclaim skid plate clearance by removing the t-case drop, the mml should do the trick I'm hardly an expert, but I recently did all this stuff to my Jeep
"The best advice I can give you is never listen to my advice" |
#4 |
My tcase shifter did bind and just plain felt "weird"(for lack of better term). I got the Advance Adapters linkage relocator and it shifts so smooth now and not once has popped out of 4-low, even after 8 hours of continuous wheeling. Just my .02
Red Jeep Club Member #454 1998 ZJ - The wife's 1997 TJ - Mine |
#5 |
I also have a 3" lift with a mml/bl with no tcase drop and I have no vibes.
#6 |
Junior Member
Thanks for the info. I haven't drove the jeep with out the TC lowering kit but I will have to try it. I would really like to run 33s so that is why I want to do the BL and MML.
#7 |
Junior Member
Hey Graves how dose your TJ handel on road with the aussie locker in the front?
#8 |
#9 |
Corporate Whore
It feels a bit different that before. not better or worse, just different. But offroad its like I am cheating climbing hills compared to with open diffs. I am very happy with it.
#10 | |
#11 |
Sometimes installing a mml will add more vibes. The reason being is that the mml does not have as soft of rubber or polyurethane as the factory. I kept my factory mounts and used the JKS bmml. Same amount of work for less money and no additional vibes.
If you do the bl and bmml at the same time your linkage should be just fine, even if you did the belly up to boot. I had no issues. You may need adj uppers in the rear if you do the belly up to help with the ds angle.
2005 Red Rubi Unlimited Auto WARN M8000, 3/8 Synthetic line, Kilby, Jeeperman, Jeepmedic, RE SF 4.5- all adj arms, RS9000x, TW shaft, 37" MTr's, RockCrusher, Currie, Rockhard, Alloy USA. Jeep Pics |
#12 | |
#13 | |
Why spend over $100+ on aftermarket to see if you get vibes or not? Everyone has their fav's Still the same work less cost and no worries about vibes.
2005 Red Rubi Unlimited Auto WARN M8000, 3/8 Synthetic line, Kilby, Jeeperman, Jeepmedic, RE SF 4.5- all adj arms, RS9000x, TW shaft, 37" MTr's, RockCrusher, Currie, Rockhard, Alloy USA. Jeep Pics Last edited by RedRubiconLJ; 08-31-2008 at 02:43 PM.. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
