body lift or budget boost - JeepForum.com
post #1 of 16 Old 10-17-2007, 01:14 PM Thread Starter
RON310
RON310's Avatar
Is it easier to install a body lift, or a budget boost.
I don't want to buy new shocks and springs, as mine are fairly new.
Opinions?
RON310 is offline
post #2 of 16 Old 10-17-2007, 01:19 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
easier to to BB but if you dont wana do new shocks then your stuck with BL as you current shocks wont be long enough
RnEmOvr is offline
post #3 of 16 Old 10-17-2007, 01:22 PM
MikeHeichelbech
^ Sorry but I have to disagree. Having done both to my T.J. I can say with confidence the Bodylift is eaiser provided you do a motermount lift at the same time. That being said neither one (BB or Bodylift) is very hard.
MikeHeichelbech is offline
post #4 of 16 Old 10-17-2007, 01:23 PM
mdm
Farm Wheeler
Neither one is at all difficult. The BL would probably take you less time.
Depending on your source for the BB it will give you 1.75 to 2.25 inches. Some of the BBs that advertise 2" are actually 1.75".
A BB does not make you buy new springs. You should get new shocks with it.
Unless there was a specific reason for doing a BL instead of the BB, I'd go with the BB and get my frame 2" further away from the ground.
mdm is offline
post #5 of 16 Old 10-17-2007, 01:29 PM
bigV
bigV's Avatar
you can do a 2" BB and keep your existing shocks
both are very easy to do, it depends on what your plans are for your Jeep
bigV is offline
post #6 of 16 Old 10-17-2007, 01:29 PM
MikeHeichelbech
And he can run his stock shocks with a B.B. Geting longer ones would be a good idea but the stock ones will strech the 2in without issue.
post #7 of 16 Old 10-17-2007, 02:37 PM
VinoTJ
VinoTJ's Avatar
A body lift is easier to install than an BB.
BLs over 1.25 are not recommended - unsightly - safety concerns.
BB is a great way to run 31s (while discoed)
What is your intent? Talk to us!
2008 Wrangler Unlimited X
VinoTJ is offline
post #8 of 16 Old 10-17-2007, 02:44 PM
RnEmOvr
RnEmOvr's Avatar
having done a few BLs and hand full of lifts i think the BB is easier, considering you have a spring compressor (which are easy to me) thats all considering everything goes as planned on bolt lifts, the other think to think about is more bolts with the BL that could give you issues (since you cant get PB blast to all of them) and why do ppl say dropping the fan shroud is so hard? its WAY easier then doing a MML, and ALOT less time consuming
RnEmOvr is offline
post #9 of 16 Old 10-17-2007, 02:46 PM
eclipse27
A body lift would be alot easier. A bb is easy...but you will need new shocks if you offroad. Body lift wont give you any ground clearnace but will help with fender clearance. You could always start small with a 1-2 in body lift. And go from there.
4-4.5 inch susp. lift. 1 in performance acs. body lift. 5 in offroad foglights. Brushgaurd. Atoz corner armors.Round 4in taillights.D35/30 combo. upgraded horn.radio.8inbazzoka tube.highlift jack. 1.5in wheel spacers. 33' goodyear wrangler mt's.
eclipse27 is offline
post #10 of 16 Old 10-17-2007, 03:25 PM Thread Starter
RON310
RON310's Avatar
I don't go offroad that often anymore. I've been driving jeeps for a while now, @ 15 years (on my third wrangler), and they have been getting lower as i get older. (YJ - 3" lift, TJ - 2.5" lift, latest - no lift).
I think a jeep looks better lifted and I want to increase the distance between the fenders and the tires (so I could go to a bigger tire down the road).
I don't want to change the suspension. I only have 10K miles on this one and don't want to void the warrantee or replace any "already working" parts.
It's an 06 Rubicon. I like the stock rims and will be keeping them. If I go with a body lift, it would only be an inch, as I agree w/ all the comments on taller body lifts.... If I go with a BB, I would want to keep my existing shocks.
I was originally leaning towards a BL, but I'm concerned with shifting issues.
RON310 is offline
post #11 of 16 Old 10-17-2007, 03:51 PM
VinoTJ
VinoTJ's Avatar
Under those circumstances, I would not lift it at all. Rubis look great as they are (IMHO) and they sure do hold their own offroad even with 31s.
If you want a little more room, add a BL, but you have other things to contend with - like the gap at the rear bumper - most do not mind it - but I went the route of a tire carrier that adjusts up 1 inch.
BL and 32s if you want it to look bigger than your neighbor's stock Rubi.
VinoTJ is offline
post #12 of 16 Old 10-17-2007, 05:01 PM
TheBoogieman
Made in the USA
TheBoogieman's Avatar
No comparison.BL takes an hour tops,BB takes a couple hours if nothing is rusted (fat chance)
TheBoogieman is offline
post #13 of 16 Old 10-17-2007, 05:15 PM
HTOR
HTOR's Avatar
Werd. I knocked out a body lift in a lunch break.
Bugest boost however took a weekend, due to rusted bullhonkeytonky all over the jeep (first stage of lifting since i got her)
If you can build it, i will break it.
Team Crazy, and Mr Diameter Custom Machine.
"More Balls than you can shake your nuts at."
Jeep 1: 2000 Jeep Wrangler Sport - Its got goodies:)
Jeep 2: 1995 Jeep Grand Chero Limited - Its gonna go fast.
HTOR is offline
post #14 of 16 Old 10-17-2007, 08:30 PM Thread Starter
RON310
RON310's Avatar
BL it is.... I figure I could always add a suspension lift down the road if things change. as far as the gap at the back bumper, i don't really mind.
Can anyone point out any issues I may have with shifting, after the BL is installed.
I'm looking at getting the Daystar 1" BL unless anyone can recommend a better kit?
Anyone know the torque specs for the body lift bolts?
RON310 is offline
post #15 of 16 Old 10-17-2007, 08:52 PM
06flex
06flex's Avatar
30-35 ftlb
http://www.4x4xplor.com/bl.html
Stu website supporter.
One of the best jeep websites out there for reference. If you can help please do.
You didn't correct the problem, you only worked around the real problem.
06flex is offline
Body lift VS. Budget Boost jake7893 TJ Wrangler Technical Forum 48 08-20-2009 07:59 AM
What's the difference between a Budget Boost and a Body Lift staquinas TJ Wrangler Technical Forum 26 08-06-2009 01:14 AM
Jeep (budget boost or body lift) JCWrestler TJ Wrangler Technical Forum 14 07-02-2008 05:20 PM
Budget Boost and Body Lift question rooster5333 JK Wrangler Technical Forum 5 10-28-2007 03:11 PM
Budget Boost & Body Lift Bad Idea? DesertTJ TJ Wrangler Technical Forum 17 02-24-2007 05:25 AM
