Body bolts rusted out - JeepForum.com
post #1 of 13 Old 11-13-2009, 09:21 AM Thread Starter
mcdcrook
I bought a pair of Black Mountain Side/Nerf Bars that attach to the body bolts, no drilling required. I went to install them last night but the body bolt was rusted and had worn away the threads, rendering it unable to be screwed back in.
Here's a picture of the body bolt assembly, with the nerf bar attachment: DSC04833 on Flickr - Photo Sharing!
Here's a picture of the body bolt itself: DSC04836 on Flickr - Photo Sharing!
How do I replace this? All the threads are worn almost smooth! Any ideas appreciated.
mcdcrook is offline
post #2 of 13 Old 11-13-2009, 09:34 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Are you sure you read the directions on how to install that bracket?
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #3 of 13 Old 11-13-2009, 09:47 AM Thread Starter
mcdcrook
Yes, I'm pretty sure.
mcdcrook is offline
post #4 of 13 Old 11-13-2009, 09:50 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Well, if you're sure and that's really the way that bracket mounts to hold a nerf bar, you really should entertain another way of protecting your rockers.
I am Savvy
post #5 of 13 Old 11-13-2009, 09:54 AM
-dirt-
I'm here in the Gump too, and I have a set of the stock body bolts I'll give you, if you need them. They wont' work with a body lift though, as they are too short. And I can't tell if you have a BL or not from the pics...
-dirt- is offline
post #6 of 13 Old 11-13-2009, 09:54 AM
Niceface
Aside from the mounting....the bolt can be bought at any local hardware store. Take the bolt with you and ask for help matching sizes. Your wanting Grade 8 hardware. It will be yellow in color (yellow zinc plated) Course thread.
Niceface is offline
post #7 of 13 Old 11-13-2009, 09:58 AM Thread Starter
mcdcrook
I don't have a body lift, dirt_j00. I's appreciate the bolts! I'll send you a private message for contact info.
My question is, since the threads are worn out, will I even be able to screw a new bolt in? What do I do if the threads in the undercarriage are crapped out?
mcdcrook is offline
post #8 of 13 Old 11-13-2009, 09:59 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Which course... Golf, race, or dinner?
I am Savvy
post #9 of 13 Old 11-13-2009, 10:00 AM
-dirt-
I knew that was coming.
-dirt- is offline
post #10 of 13 Old 11-13-2009, 10:00 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I'm wondering why you don't have the stock bolts any longer? Are all the bolts like the one in the pictures?
I am Savvy
post #11 of 13 Old 11-13-2009, 10:05 AM Thread Starter
mcdcrook
I only removed, the one, so I'm not sure if the others are the same size. Should they be longer? If so, how long is ideal?
mcdcrook is offline
post #12 of 13 Old 11-13-2009, 09:35 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
It's not the length, it's the style. Factory is a flange head trilobular thread and very high quality.
I am Savvy
post #13 of 13 Old 11-13-2009, 09:43 PM
jdub2k5
heres how my steps are mounted... please stfu about the body lift
2004 TJ 4.0 5 speed, 2 inch body lift, barricade armor, 4.5 bds lift, 35 mtz, sye, and tons more
jdub2k5 is offline
Removing rusted oil pan bolts??? ppandr YJ Wrangler Technical Forum 7 03-01-2010 12:40 PM
rusted tub bolts body lift..... gabulldogs YJ Wrangler Technical Forum 9 02-11-2009 06:55 PM
Removing B/L. All the !?$#@ bolts are rusted! danny2go YJ Wrangler Technical Forum 4 09-30-2008 09:55 PM
Help Removing Rusted Bolts? ddwyer YJ Wrangler Technical Forum 34 07-17-2005 09:56 PM
Rusted Bolts? jeepdan TJ Wrangler Technical Forum 3 08-14-2002 12:33 PM
