Quantcast Body Armor Swing Away Mount Question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Body Armor Swing Away Mount Question
Front and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big Red
Old 05-21-2006, 10:43 AM   #1
FmrVette
FmrVette's Avatar
2008 XK Commander
The Body Armor rear swing-away (54") is on and I finally have all of the bolts tightened down (the alignment of the frame tie-in's allows for zero tolerance - it was an experience getting everything lined up!).
The question (this on an '06 TJ X):
The three original spare tire rubber mounts that are mounted to the 'gate prevent the swing arm from closing.
The minimal instructions that came with the bumper just state to "reinstall" the mounts (at no point do the instructions mention taking the mounts off of the tail gate!).
The one closet to the passenger tail lamp was 'way too thick for the swing to even get near the closed position; I've sawn half of the mount off so that it makes contact with the 'gate and the swing when the swing is closed. The bottom mount and the driver's side mount I've not modified, but the mounts are "indented" where the swing arm presses against them.
The question (ya'll just knew there had to be a question in here eventually ):
How have others solved this issue? Removing the mounts altogether means a rattling swingaway with nothing to keep it from banging into the 'gate. Not modifiying the mounts, at least to some extent, prevents the swing from closing.
Has anyone a better suggestion (please, nothing like "don't buy the Body Armor bumper" ) on dealing with the mounts?
I like the bumper (no welding or drilling and I was able to install it without assistance, which is a huge plus for me); the only drawback is having to move the swing before opening the tailgate when accessing the trunk (pretty much inherit in the design, of course!). But I've gotten really curious about the rubber mounts, and how others have handled the issue.
Jim
"Basically, I'm for anything that gets you through the night - be it prayer, tranquilizers or a bottle of Jack Daniels.” - Frank Sinatra
"When the last Blackhawk helicopter goes to the boneyard, it will be on a sling under a Huey." - Every Huey pilot that lived through it.
'95 YJ, '00 XJ, '06 TJ, (Current:) '08 XK
FmrVette is offline   Reply With Quote
Old 05-21-2006, 11:47 AM   #2
Rocky529
Jeep
Rocky529's Avatar
On my Jeeperman swingaway, I installed it and trimmed down the rubber mounts too much and it ended up rattling. I put some washers behind the rubber mounts and now it is a tight, rattle-free fit. Your only option is to trim down the rubber mounts, you did the right thing.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 05-21-2006, 12:15 PM   #3
dl425
Mine won't close with the rubber mounts, so I just took all 3 of them off and there is no rattle.
2005 Red Rocky Mountain Edition
4.0 6 speed
Jeeperman Skidz-Body Armor front and rear bumpers
http://i15.photobucket.com/albums/a398/dl425/DSC_0338.jpg
Rocky Mountain Edition Club Member #2
dl425 is offline   Reply With Quote
Old 05-21-2006, 01:42 PM   #4
onemoretry
Oldbie
onemoretry's Avatar
loose
I did the body armor too, but mine was loose. The only adjustment I had to make was to tighten in the u bolt for the latch.
sorry no help, but given the tolerances, it is surprising.
Fat, balding, kind of deaf... oh wait, you meant the jeep...
Scratches, dents, recently revived transmission, more coming soon.
onemoretry is offline   Reply With Quote
Glock Forum
