blown np231 - JeepForum.com
post #1 of 3 Old 10-16-2010, 05:54 PM Thread Starter
stormtj
blown np231
Well today i finally got my jeep running. for those who saw my previous threads about how it would not start i turned out to be a bad ecu. i only have my rear regeared to 4.88 at this time. My transfer case was stuck in 4hi. I went about 4 feet with like that. now the transfer case has a slapping noise in it. Did i grenade my tc? if so would that be just the chain that broke most likely?
stormtj is offline
post #2 of 3 Old 10-16-2010, 08:44 PM
BYuen
BYuen's Avatar
You might have cracked or broke something inside. I would guess you stretched your chain?
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #3 of 3 Old 10-16-2010, 10:11 PM
RubiconRazorbac
RubiconRazorbac's Avatar
There's no telling until you pull it and check it out.
My advice to you is to drink heavily.
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
np231 , problems
Blown head gasket actually a blown motor :( KidFresh TJ Wrangler Technical Forum 8 01-11-2010 09:11 PM
Blown 2.5L mokey35 YJ Wrangler Technical Forum 3 06-14-2008 01:29 PM
Would a '89 NP231 TC & Tranny work w/ my '97 NP231 TC & tranny? MtnHighTJ TJ Wrangler Technical Forum 8 04-13-2007 06:38 PM
Blown up YJ value. Bgeddes YJ Wrangler Technical Forum 8 01-15-2006 10:22 PM
Questions about Swapping out Old NP231 for New NP231 computerguy YJ Wrangler Technical Forum 2 08-11-2004 01:42 PM
