Quantcast Blower Speed Problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Blower Speed Problem
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Old 01-03-2008, 10:01 AM   #1
Bears Fan
Blower will not work on the lower 2 speeds. I understand this problem should be some kind of resistor. Does anyone have any pics. of what to look for. I've done a search and no one seems to have any pics. of what they are talking about.
Thanks!!
Bear Down, Chicago Bears!!
Bears Fan is offline   Reply With Quote
Old 01-03-2008, 10:36 AM   #2
ppandr
Have the same problem on mine......interested to see the responses. I was thinking that it was a switch problem????
ppandr is offline   Reply With Quote
Old 01-03-2008, 10:40 AM   #3
Jerky bump
I bet this happens every winter on JF.
Hi Jerry!
Jerky bump is offline   Reply With Quote
Old 01-03-2008, 11:10 AM   #4
Benfield
You are right mine was doing the samething lastweek! Part was around $15.00 and took about 10 min. to change is located right behind the Glove box. Just take the glove box off and you can not miss it has 4 wires coming out 2 screws hold it in 8mm.
Benfield is offline   Reply With Quote
Old 01-03-2008, 11:57 AM   #5
gnfreak
same problem here in the 04 i got last year. do you have a part number?
gnfreak is offline   Reply With Quote
Old 01-03-2008, 12:48 PM   #6
Bears Fan
I took a look at lunch and don't see what it is you're talking about. Please get me some pics.
Old 01-03-2008, 03:37 PM   #7
Bears Fan
Found this thing finally. For all who want to know...it's located just above the interior lamp on the lower right side of the dash. If you pull your glove box out, it will be down and to the right w/ four wires coming out.
Old 01-03-2008, 04:28 PM   #8
dbdbdb3
I replaced my blower switch resistor last night but still have the same problem. Tonight I am digging into the dash to check the switch and see if there is anything wrong there. Any suggestions on other causes for the lower blower settings not working?
dbdbdb3 is offline   Reply With Quote
Old 01-03-2008, 05:52 PM   #9
gnfreak
resistor part #
ok, went and bought the oem part at my local dealer. part # 5139719-AA Resistor
i was charged 22.95 + tax. will try to install tomorrow.
fixed....but i'd like to meet the engineer that thought that was a good place to put the part and maybe the one who designed the clip as well!!
Old 01-04-2008, 01:44 PM   #10
dbdbdb3
Well I checked the switch all is working fine. I can jump past the resistor and make the fan work on all three low settings. although it blows at high speed. could it be the relay that is the problem? and did I blow the new resistor out by a possible overload of power passing through the relay
Glock Forum
