Blower Resistor Replacement 05 LJ - JeepForum.com
 1Likes
post #1 of 46 Old 06-10-2010, 05:24 AM Thread Starter
Boundless
Symptom of a faulty blower resistor is, blower only works on speed "4". I got my replacement resistor for $24.99 from Autozone part # JA1476 AutoZone.com | | Blower Motor Resistor | BLOWER MTR RESISTOR
below is just a guide on how to replace the blower resistor, although maybe not the best way, it's the way I did it.
first to remove glove box, slide out the retaining strap on the right side then lower door till you can pull it off the hinge
Next I removed the interior light just under the glove box (1/4"). This made it easier to remove the resistor. You can use this as a work light or just remove the bulb so you don't get burnt.
Then from above though the glove box opening, I used a 1/4" drive 8MM (5/16) swivel socket with extension and ratchet to remove the top screw (one of two screws holding the resistor), seen just under the brightly colored connector.
Then from below I removed the bottom screw using the same 8MM swivel socket set up.
With both screws removed I just slid the resistor out of its location then pulled the harness downward (why I removed the light) you can now see why it's faulty (burnt)
Now disconnect the resistor plug by first releasing the plug retaining clip, pull the red clip out slightly. (sorry for the blurry pic, camera got fogged up. it was very humid out) first pic shows the red retaining clip in the lock position, the second in the released position
in the below pic you can see the difference between the new (now plugged in) and the old burnt resistor (in my hand).
Here's a pic of the old resistor and the box the new one came in.
Well just reverse the above to install and enjoy your lower blower speeds again.
Note: do not use the blower with the resistor removed (not in it's proper place in the blower's air stream) or you can burn it out.
Disclaimer: some of the pictures were taken during reassembly because of the fogged up camera.
__________________________________________
Rusty
Satellite Bch, FL
2005 Jeep Wrangler Unlimited (LJ) 6cyl, 4spd auto, dana 30/44 3.73, rear trac-loc, hard top, BFG KM2 35/12.5 x 15 on rattle can black stock Ravine wheels & 1.5" spacers, trimmed flares, budget PA 1" BL & RC 1" MML, Ford Explorer roof rack, Hella e-code headlight housings, 55 watt DDM HID Hi/Lo 6000k, EBC Yellow Stuff front brake pads, Platinum P4 battery, Rusty's 3" 305s front and 303s rear springs, RC rear track bar bracket and Hella 500FFs with DDM's 55watt 6000k H3 HIDs on windshield hinge brackets. Currie's front upper and lower control arms. Hummm whats next? Building a Dana HP30 with 4.88 and ? locker
Boundless is offline
post #2 of 46 Old 06-10-2010, 08:48 AM
timberwolf0122
I have got to sit down an build a better PWM fan controller, why do they even use resistors to control the motor?
Atheist Jeep Club Member #2
Doctor Who has died 13 times, is on his 14th regeneration and has a time machine, beat that Jesus.
timberwolf0122 is offline
post #3 of 46 Old 06-10-2010, 06:29 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
So you can have differnt speeds...
Knuckelhead is offline
post #4 of 46 Old 06-18-2010, 12:29 AM
explorerlyon
I am trying the same repair. I cannot get the wiring harness disconnected from the resistor. I have pulled the red lock out. What nest? Is there a catch somewhere? I have pulled and tugged and connot get the harness disconnected. Help!
EDIT: Got if off finally
05 Rubicon Unlimited, Automatic
explorerlyon is offline
post #5 of 46 Old 06-18-2010, 08:58 AM Thread Starter
Boundless
Glad to hear you got it off... mine was a little hard to disconnect also . I think the connectors get stuck due to the heat and or condensation.
that's why I found it easiest to pull the resistor out and down with the plug, so I would have more room to hold each part as I separated them.
Rusty
Satellite Bch, FL
post #6 of 46 Old 06-18-2010, 09:20 AM
2004sahara
not as easy as some would have you belive......but it is a do it your self job.
2004 sahara, 2 inch BDS spring lift, BDS discos, 31bfg at, on ravines.
2004sahara is offline
post #7 of 46 Old 06-18-2010, 03:33 PM
explorerlyon
I created a thread on how to test if the resistor is bad before replacing it. Here is the link: http://www.jeepforum.com/forum/f9/bl...6/#post9648090
But, after the work of removing the resistor, I would have replaced in regardless with a new one, even if the old one was not bad.
post #8 of 46 Old 06-18-2010, 04:34 PM Thread Starter
Boundless
nice helpful addition, thanks
Rusty
Satellite Bch, FL
post #9 of 46 Old 09-19-2010, 09:41 PM
Squwearley
Newbie
Squwearley's Avatar
thanks
Thanks for the step by step... made doing this job really easy
Squwearley is offline
post #10 of 46 Old 09-20-2010, 05:26 AM Thread Starter
Boundless
you're welcome. Glad it was helpful
Rusty
Satellite Bch, FL
post #11 of 46 Old 09-20-2010, 06:02 AM
HKB3
Any idea if a bad resistor will throw a check engine light?
What Next?
2006 TJ Rubicon
HKB3 is offline
post #12 of 46 Old 09-20-2010, 06:59 AM
Neil F.
The HVAC blower has nothing to do with OBDII emission system monitoring.
Neil F. is offline
post #13 of 46 Old 09-20-2010, 11:14 AM
FireMedic777
Awesome! Just replaced mine today for about the same price at advanced. Thanks for the good tech thread!
FireMedic777 is offline
post #14 of 46 Old 10-23-2010, 08:10 AM
StangsAndJeeps
great guide. never knew i could bend that much.
Stumplifter likes this.
StangsAndJeeps is offline
post #15 of 46 Old 11-16-2010, 08:06 PM
Boston_Wheeler
Just did this myself. Thanks for the write-up. Definitely difficult to disconnect the harness. Also, one thing I found to be helpful. I secured the new resistor prior to reconnecting the harness. I had more room and found it much easier this way.
Boston_Wheeler is offline
blower , motor , replacement , resistor
If it's not my blower motor resistor, it's my what??? blower still doesn't turn on.. bortz1892 TJ Wrangler Technical Forum 13 08-02-2010 10:13 PM
Blower Motor Resistor Replacement Saisling TJ Wrangler Technical Forum 5 07-07-2009 07:28 AM
Was not the Blower Resistor tmwoodall TJ Wrangler Technical Forum 1 03-22-2007 07:20 PM
Is this blower the resistor? Eyeguy77 TJ Wrangler Technical Forum 6 02-22-2007 08:13 PM
Blower Motor Resistor HOT HOT! 00TJDave TJ Wrangler Technical Forum 3 10-17-2004 12:49 PM
