Blower Resistor Replaced, stereo stopped working - JeepForum.com
post #1 of 5 Old 07-01-2013, 05:18 PM Thread Starter
Florida_Model
So I only had one fan speed on the AC working and decided to replace the resistor. All speeds work now, but my headunit no longer works, and when you turn the key back (as opposed to forward to turn it on) none of the auxiliary electronics work (stereo, dome light, etc).
Any ideas? Is there a loose wire? Did I damage something? I disconnected the battery before I took anything apart, any help would be greatly appreciated. rush hour traffic sucks without music.
Chris
Get busy living, or get busy dying
Florida_Model is offline
post #2 of 5 Old 07-01-2013, 09:55 PM Thread Starter
Florida_Model
No one has any input? I'm checking the fuse on the unit, but any insight would be a great help!
post #3 of 5 Old 07-01-2013, 11:22 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
There are only 4 things that are supposed to work both with the key on & back in the acc. position. The radio, wipers, turn signals & cig lighter all work that way. See if any or all those work in the on position then in the acc position. Report findings & I may be able to advise further. Also check fuses 13, 14, 15, & 19 in the fuse block behind the glove box.
Rubi4MyMrs is offline
post #4 of 5 Old 07-02-2013, 12:03 PM Thread Starter
Florida_Model
Everything started working without me touching it last night while I was driving. Which is also equally as perplexing.
post #5 of 5 Old 07-02-2013, 12:27 PM
JBTJ
Means there is a poor connection somewhere.
JBTJ is offline
blower , electrical issue , resistor , stereo
