Blower Motor Resistor-Testing If It's Bad - JeepForum.com
post #1 of 1 Old 06-18-2010, 02:31 PM Thread Starter
explorerlyon
explorerlyon's Avatar
After losing the fan speed on the lower two settings, I researched this forum and learned how to replace the blower motor resistor. I used this thread for the procedure: http://www.jeepforum.com/forum/f9/bl...05-lj-1048567/
BUT: How do you determine if the resistor is bad before replacing it? The field service manual says to test the resistor by checking continuity between all of the pins. This can be done before removing the resistor. You first need to uplug the wiring harness (which is a pain). Then check continuity between each and every pin.
There are 5 pins to test
Sure enough, the one I removed did not have continuity with two of the pins The new one I purchased at the stealership this morning ($25) has continuity amoung all pins.
05 Rubicon Unlimited, Automatic
explorerlyon is offline
blower , motor , resistor
Blower Motor Resistor TJinWV TJ Wrangler Technical Forum 66 10-19-2013 03:39 AM
Blower Motor Resistor - 87 YJ DivineKaos YJ Wrangler Technical Forum 17 08-30-2012 05:58 PM
If it's not my blower motor resistor, it's my what??? blower still doesn't turn on.. bortz1892 TJ Wrangler Technical Forum 13 08-02-2010 09:13 PM
Blower Motor Resistor HOT HOT! 00TJDave TJ Wrangler Technical Forum 3 10-17-2004 11:49 AM
Blower Motor Resistor? oxygen_77 TJ Wrangler Technical Forum 8 08-28-2003 02:15 PM
