Blower Motor Resistor - Page 5 - JeepForum.com
post #61 of 77 Old 05-21-2011, 01:20 PM
jeepinmichguy_
That is you BMR in the bottom pic that looks like a credit card. Oriellys sells them for about $20. Head up there and get a new one.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
post #62 of 77 Old 05-21-2011, 03:38 PM
Slick101
Originally Posted by Jonny Jeep View Post
That's it. The design changed in later models.
thanks i just got it the pic is wrong in my 2003 fsm it shows the older connector
K&N pannel filter, got that far before i ran out of money
Slick101 is offline
post #63 of 77 Old 11-20-2011, 11:19 AM
doomtroopin
Thanks for the info. Local dealer said that the actual controls were jacked and gave me a crazy high price for a swap. $30 at Advance (yes! and even in stock!) and several curses at the jeep engineers later...I've got all 4 fan speeds. It was a huge pain in the butt getting it done, but the problem was solved.
doomtroopin is offline
post #64 of 77 Old 11-20-2011, 05:48 PM
CO_crawler
If your having any trouble all questions are answered in this thread.
Definitive TJ Blower Motor Resistor and fan speed Thread
CO_Crawler
Crawlin Slow Some Where in CO
CO_crawler is offline
post #65 of 77 Old 11-28-2011, 06:02 PM
Hillbilly88
2014 JK Wrangler
Jeep has been down for a few months. Parked it a/c was blowing good and all but 1 fan speed worked. Worked on jeep for last 2 day. Cranked it up totake it for a test drive and guess what. Fam doesnt work at all now. Anything to look for before i buy a new switch and or risistor If i pull them out will i be able to see the problem or will it possibly be hiddin. Thanks. And if its already been said. Point me in the right direction. I found this thread with the search
Hillbilly88 is offline
post #66 of 77 Old 11-28-2011, 07:02 PM
tattooed856
When I replaced my BMR the old one looked melted on the edges, I dont really know if that was the problem. I only had the high fan speed working and after replacement they all worked. Good luck
tattooed856 is offline
post #67 of 77 Old 11-28-2011, 07:07 PM
Hillbilly88
2014 JK Wrangler
Thanks. Im gunna try to pull it apart tmrw after work and see if i can find anything melted or bad conections What are the chances. Blower motor went out in my company truck today and get home and now blower doesnt work in the jeep
post #68 of 77 Old 11-30-2011, 04:50 PM
Hillbilly88
2014 JK Wrangler
I found the bmr. And it looks fine. If i can find my test light If my switch is working shouldnt i have power to the plug. And input on this will be helpfull
post #69 of 77 Old 11-30-2011, 04:53 PM
Hillbilly88
2014 JK Wrangler
Well i found test light Nd checked the plug. With switch on high 2 prongs have power the solid tan. And the black and tan. Black and tan has constant power with all setting. But when i take the switch off high. On any other setting i get no power. Except thT black and tan. So does that mean. Bad switch maybe fried the bmr. Thanks for any help
post #70 of 77 Old 12-01-2011, 11:55 AM
Hillbilly88
2014 JK Wrangler
Bump. I have power to the bmr on high. But my fan does not blow after reading threw everythin. Im gunna pull my switch out today. And maybe pull fan motor its self. But. Where is the plug for the fan motor. Does it unplug under the dash or under hood
post #71 of 77 Old 12-01-2011, 12:22 PM
Hillbilly88
2014 JK Wrangler
Found the problem. It was a bad conection on the switch. Pulled it out unplugs it. There was some corosion on it. So i cleaned it up and put dielectric grease pluged it back in and blower works on everything except speed 3.
post #72 of 77 Old 12-07-2011, 11:35 AM
Must-Be-A-Stang
Question.... sorry if I drug up an old thread.
I seem to be having the same problem here. However, If I push hard on the switch I can get 1, 2, and 3 to blow but when I let go, they stop. Is this a bad switch?
Must-Be-A-Stang is offline
post #73 of 77 Old 12-07-2011, 02:32 PM
Hillbilly88
2014 JK Wrangler
I had a bad connection. Pull it out and clean the connections and put some dielectric grease in the plug amd try it Thats what i had to do
post #74 of 77 Old 07-22-2012, 06:07 PM
BJHUMPLIK
Blower Motor Resistor for 2002 TJ, JA1476 by Duralast, $25.00 at Autozone
BJHUMPLIK is offline
post #75 of 77 Old 07-22-2012, 06:11 PM
BJHUMPLIK
Burned out Resistor is below, replacement took 10 minutes, it is easier if you move the green/yellow wire bundle connector out of the way. Be carefully unlocking the BMR from the wire harness, easier to pull the red tab out with small screwdriver, the push up on the tab before pulling...it should go easy.
Blower Motor Resistor - 87 YJ DivineKaos YJ Wrangler Technical Forum 17 08-30-2012 06:58 PM
If it's not my blower motor resistor, it's my what??? blower still doesn't turn on.. bortz1892 TJ Wrangler Technical Forum 13 08-02-2010 10:13 PM
Blower Motor Resistor, 03 TJ BloodThirsty TJ Wrangler Technical Forum 15 10-16-2009 12:40 PM
Blower motor resistor on an 05. DBLJ TJ Wrangler Technical Forum 2 06-29-2009 07:58 AM
YJ Blower motor resistor UltimatE Wrangler General Discussion 3 10-21-2008 08:00 AM
