Blower Motor Resistor - Page 4 - JeepForum.com
post #46 of 67 Old 10-06-2011, 01:09 PM
Mayfair_Jeeper
Mayfair_Jeeper's Avatar
What if it works in 1, 2, and 3, but not 4? Switch? I run it on High almost always, so that is my guess...any ideas where to get one cheap?
2006 Jeep TJ X Modded with toys
2008 Jeep Liberty Sport Stock
1987 Cherokee 4.0 Renix...Build in Process
Mayfair_Jeeper is offline
post #47 of 67 Old 10-06-2011, 01:11 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Switch is the problem then. Mine is doing the very same thing now.
Sent from planet X.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #48 of 67 Old 10-06-2011, 02:42 PM Thread Starter
TJinWV
TJinWV's Avatar
First time I've been on the forum in quite a while. Funny to see a post I started on the first page. Glad it's still helping folks out, even though it wasn't a particularly useful post.
Dan - TJinWV <>< |
2002 TJ, 2" OME lift, ARBs
TJinWV is offline
post #49 of 67 Old 10-14-2011, 02:55 PM
Dane186
Sent from planet X.
This could also be because of a bad (fan speed 4) relay. The relay is located to the right of the green plug next to the resister pack. The way you would check this is to use a multimeter and see if pin 5 is turning 12v or not when you have the switch on 4.
This is the more rare of the causes, but if it is your case than a new relay should only be 3 to 6 bucks to replace.
Dane186 is offline
post #50 of 67 Old 11-12-2011, 12:50 PM
Bigfoot410
I had speeds 2,3 and 4 for a week, then nothing. Put in a new switch and resistor but that didn't work. Pulled the blower motor and tested it with leads to the battery...DEAD. Anyhow, I think the motor died because I have water pouring out of the floor vent when it rains heavily and can't find where it's coming in. I can't afford to keep replacing blower motors....anybody else have this one?....I hate the fact I love my Jeep....stupid *%$#@ thing.
Bigfoot410 is offline
post #51 of 67 Old 11-20-2011, 10:43 AM
dougiefresh131
any part numbers for the resistor and switch?
dougiefresh131 is offline
post #52 of 67 Old 11-20-2011, 04:47 PM
CO_crawler
If your having any trouble all questions are answered in this thread.
Definitive TJ Blower Motor Resistor and fan speed Thread
CO_Crawler
Crawlin Slow Some Where in CO
CO_crawler is offline
post #53 of 67 Old 12-24-2011, 04:29 PM
Brian97TJ
Originally Posted by SaxManClay View Post
Bump, also with a link!
Blower Resistor Replacement
In case you have a TJ that is from 97-00, then your blower motor resistor will be different. I found a good link that illustrates this so those without the newer TJ can listen to our loved ones talk AND have our heat/cooling on. :-)
Was perfect for my 97! Thank You!
Brian97TJ is offline
post #54 of 67 Old 03-31-2013, 04:15 PM
lucasweatherby
New to the forum. Long time lurker. I am struggling something awful with this problem. I have purchased the part from Quadratec. I hope it is the correct piece:
When I take off the glovebox, my inside guts look differently than the picture from the OP. I Can't seem to find where this piece is at:
Here is another picture from the glovebox:
Here are a couple pics from underneath:
If someone with some know-how could help me find where this piece is to replace I would be forever grateful. I drive a 2005 Wrangler SE. Thanks in advance
lucasweatherby is offline
post #55 of 67 Old 04-02-2013, 07:12 AM
lucasweatherby
Bump... Mods should I just make a new topic since this one is too old?
post #56 of 67 Old 04-02-2013, 07:21 AM
JBTJ
What is your question?
JBTJ is offline
post #57 of 67 Old 04-02-2013, 07:37 AM
lucasweatherby
Where exactly is the piece located at that I am replacing? I have looked all in there but don't see a similar piece. All of the guides say this is a quick process, but I am super struggling. If someone could circle one of my images and point me in the direction that would be great.
Thanks again.
post #58 of 67 Old 04-02-2013, 07:39 AM
JBTJ
The resistor. is hidden in the air plenium. so it doesn't stick out. go back on page 1 post#8 and click on the link and see if that one helps you.
JBTJ is offline
post #59 of 67 Old 04-02-2013, 07:46 AM
lucasweatherby
Ok that makes a little more sense. I am at work now. I will have to look at it when I get off. How do you release that green piece. It seemed pretty firm locked in place when I was fooling with it on Sunday.
post #60 of 67 Old 04-02-2013, 07:55 AM
JBTJ
See the red tab that's in front of it? Slide it to one side, only goes one direction, then squeeze the release and pull apart.
JBTJ is offline
Blower Motor Resistor - 87 YJ DivineKaos YJ Wrangler Technical Forum 17 08-30-2012 05:58 PM
If it's not my blower motor resistor, it's my what??? blower still doesn't turn on.. bortz1892 TJ Wrangler Technical Forum 13 08-02-2010 09:13 PM
The $1.65 blower motor resistor bdevr TJ Wrangler Technical Forum 8 02-06-2010 10:32 PM
YJ Blower motor resistor UltimatE Wrangler General Discussion 3 10-21-2008 07:00 AM
97' TJ Blower motor resistor - where is it? Michele TJ Wrangler Technical Forum 3 02-26-2003 03:59 PM
