Blower Motor Resistor - JeepForum.com
post #1 of 67 Old 12-05-2006, 09:39 AM Thread Starter
TJinWV
TJinWV's Avatar
Anyone have that thread about replacing the blower motor resistor bookmarked?
Dan - TJinWV <>< |
2002 TJ, 2" OME lift, ARBs
TJinWV is offline
post #2 of 67 Old 12-05-2006, 09:47 AM
Conundrum
Conundrum's Avatar
Matt
2001 Jeep Wrangler Sport 4.0L - Amber Fire Pearl Coat
1981 DeLorean DMC-12 VIN: 2953
Conundrum is offline
post #3 of 67 Old 12-05-2006, 10:55 AM
Ivan
Try this Blower Motor Control Switch Replacement - TJ
One of the 1,993 Golden Eagles produced in 2006.
Ivan is offline
post #4 of 67 Old 12-05-2006, 11:35 AM Thread Starter
TJinWV
TJinWV's Avatar
Originally Posted by Ivan
That's the switch, not the resistor. Thanks though.
Originally Posted by conundrum1984
I added that to my sig a couple years ago. Only 4 or 5 people have mentioned it.
Dan - TJinWV <>< |
TJinWV is offline
post #5 of 67 Old 12-05-2006, 12:59 PM
Ivan
That's the switch, not the resistor. . .
OK,
I cut & pasted this quite a while back. Didn't include the web link so no reference to who wrote it . . .
2003 SE, 28,000 miles.
Fan stopped working only on #2 position.
Replacement part #1-05139719AA. This is the "credit card" type resistor.
Cost me 16 US$ (with discount) from local dealer.
Plastic bag that part came in says "Made in USA", however, the part itself is marked "Made in Mexico". The old part was made in Mexico as well.
Blower Resistor: 4885456AB - $20.45
Switch: 5011214AA - $20.25
How to: This is what I did FWIW.
1. Disconnect negative battery terminal. My OEM radio did not lose it's station presets.
2. Remove passenger side door. Crawling around is just so much easier with the door removed and not banging on your legs. (OPTIONAL)
3. Remove glove box door.
4. Remove the screw attaching the under dash light on the passenger side (if you have a light there). Move the light out of the way. No need to unplug it.
5. Looking through the glove box opening, there is a large GREEN connector.
Unplug it and remove the bottom half from the heater box. Pull the bottom half down and out the bottom of the dash.
6. Now you can see and access the right side screw holding the resistor in.
7. Remove the two (8mm wrench) resistor screws. The left one from under the dash and the right one through the glove box opening.
8. Pull the resistor out of the heater box.
9. Unlock (the red thingy) the harness connector on the resistor and remove the resistor from the harness. Credit goes to an earlier poster for this excellent tip.
10. Plug in the new resistor and lock (the red thingy) the connector.
11. Assemble in reverse order.
This took me a little over an hour because the green connector gave me a hard time while trying to remove the bottom half from the heater box. You have to slide it up or down quite firmly to get it off. Do not pull straight out.
As always, YMMV.
Ivan is offline
post #6 of 67 Old 12-05-2006, 05:23 PM
treehugger
Here this may help you out.
http://www.jeepinohio.com/viewtopic.php?t=2631
Nothing left to do but smile mile smile....
2004 Rubi, Bright silver metalic., 2.5 OME HD, JKS adj track bars, JKS quick disco's, JKS 1.25 BL, JKS BMML, Rockhard 4x4 front & rear bumpers, Cobra 75 CB
treehugger is offline
post #7 of 67 Old 06-23-2009, 07:51 AM
SaxManClay
I needed this too. Thanks!
SaxManClay is offline
post #8 of 67 Old 06-23-2009, 08:12 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
TheBoogieman is offline
post #9 of 67 Old 12-28-2009, 01:43 PM
ads357
I know this thread is a little old, but I just wanted to say thanks. I just used it to change my resistor and it solved my problem.
ads357 is offline
post #10 of 67 Old 12-31-2009, 01:31 PM
paris-dakar
Bumping so it's easier to find.
paris-dakar is offline
post #11 of 67 Old 01-07-2010, 04:22 PM
SaxManClay
Bump, also with a link!
Blower Resistor Replacement
In case you have a TJ that is from 97-00, then your blower motor resistor will be different. I found a good link that illustrates this so those without the newer TJ can listen to our loved ones talk AND have our heat/cooling on. :-)
post #12 of 67 Old 01-09-2010, 10:14 PM
Palagi
thanks for this, very easy. bump
Palagi is offline
post #13 of 67 Old 01-14-2010, 02:09 PM
SarahBecky
I meant to place this on this thread and placed it on another. THANKS for your help. Got my motor blower resistor changed without too much trouble thanks to this thread. Somehow I created a new problem though, with a squeal on all fan settings. It gets louder the higher the setting. I know it's from how we replaced the resistor but I can't figure out what would cause it. Any suggestions?
SarahBecky is offline
post #14 of 67 Old 01-14-2010, 02:41 PM
1ATony
Vendor
1ATony's Avatar
If anyone need to replace their Jeep Wrangler Blower Motor Resistor we stock them.
SHOP HERE FOR AWESOME
1ATony is offline
post #15 of 67 Old 01-25-2010, 05:49 PM
yosemitejeep
Thanks for all the info! As soon as it stops raining I will attempt this repair!!
yosemitejeep is offline
Blower Motor Resistor - 87 YJ DivineKaos YJ Wrangler Technical Forum 17 08-30-2012 06:58 PM
If it's not my blower motor resistor, it's my what??? blower still doesn't turn on.. bortz1892 TJ Wrangler Technical Forum 13 08-02-2010 10:13 PM
The $1.65 blower motor resistor bdevr TJ Wrangler Technical Forum 8 02-06-2010 11:32 PM
YJ Blower motor resistor UltimatE Wrangler General Discussion 3 10-21-2008 08:00 AM
97' TJ Blower motor resistor - where is it? Michele TJ Wrangler Technical Forum 3 02-26-2003 04:59 PM
