Blower Motor Resistor, 03 TJ - JeepForum.com
post #1 of 16 Old 10-15-2009, 06:32 AM Thread Starter
BloodThirsty
Been searching the forum and everything I find is for 02 and older model years. I may be missing something in my search though.
Anyway my blower just started to crap out on me. Only speeds 3 and 4 work now and thats not going to cut it.
So my question is is the resistor the same in the 03 as it is in older model TJ's? Also where is the best place to get a replacement? I haven't checked pricing at the dealership yet.
BloodThirsty is offline
post #2 of 16 Old 10-15-2009, 06:34 AM
krelja
Dealership has decent prices I just picked mine up in nj for 20 and change. There is a write-up on in somewhere but if you take out your glove box there is a green plug there. The resistor is right behind it being held in by 2 8mm bolts
krelja is offline
post #3 of 16 Old 10-15-2009, 06:36 AM Thread Starter
BloodThirsty
Nice! Thanks!
post #4 of 16 Old 10-15-2009, 06:42 AM
krelja
krelja is offline
post #5 of 16 Old 10-15-2009, 09:17 AM
Neil F.
Neil F. is offline
post #6 of 16 Old 10-15-2009, 09:52 AM
Mick VT
Mick VT's Avatar
If its 3 and 4 that work its likely not the resistor - when that fails you only have off and 4; 2 and 3 are the speeds provided by the resistor. I would check the switch first
Mick VT is offline
post #7 of 16 Old 10-15-2009, 10:43 AM
Neil F.
Is that true or can the individual resistors go one at a time? Mine went one by one. I currently only have 4. First 1 went, the a month or two, 2 went, then later 3.
Neil F. is offline
post #8 of 16 Old 10-16-2009, 07:53 AM Thread Starter
BloodThirsty
Just for the record is was the resistor. So if anyone ever looses level 1 and 2 that could be the issue. Mine works great now.
It was tough to get to though.
post #9 of 16 Old 10-16-2009, 08:04 AM
glockster
That's not quite true. You'll lose whatever speed's circuit loses the resistance. It can be 1,2 or 3. In my case it was 2.
Marco
glockster is offline
post #10 of 16 Old 10-16-2009, 09:43 AM
DeconsTructionJ
DeconsTructionJ's Avatar
2007
right on I was just thinking about fixing mine I lost 1 & 2 also
Canadian Jeep Club Member #23
Sold My Rubicon, I will have another jeep someday
DeconsTructionJ is offline
post #11 of 16 Old 10-16-2009, 09:47 AM
Skelator03
resitor is sooooo easy to install i would let my little cousin do it with his fisher price tools
Skelator03 is offline
post #12 of 16 Old 10-16-2009, 09:53 AM
gaucho919
the resistor goes bad bc the blower is drawing too much current, right? I replaced my resistor but it got extremely hot right away, could my blower be bad?
"The journey is the destination"
gaucho919 is offline
post #13 of 16 Old 10-16-2009, 10:44 AM
Neil F.
I can't say in your case but the resistors going is very, very , very common here and other Chrysler vehicles. It happens all the time on my Durango/Dakota foums.
Neil F. is offline
post #14 of 16 Old 10-16-2009, 11:10 AM
03rubiconMG
The 2003 and up blower motor resistor looks much different than the years up to 2002. Just go to the dealer and pick one up for under 25 bucks.
When my blower motor resistor wore out each of 1,2 and 3 wore out and stopped working slowly till i only had 4. So at one point 3 and 4 were working untill 3 died. Easy cheap place to start.
2003 white rubicon on 37s
03rubiconMG is offline
post #15 of 16 Old 10-16-2009, 11:12 AM
03rubiconMG
the blower motor resistor wears out because the blower motor gets corroded and over time needs to draw more electricity for it to work. due to this the resistor fails because of too much current.
If it's not my blower motor resistor, it's my what??? blower still doesn't turn on.. bortz1892 TJ Wrangler Technical Forum 13 08-02-2010 09:13 PM
blower motor resistor XJKyle1389 TJ Wrangler Technical Forum 2 11-10-2009 02:06 PM
YJ Blower motor resistor UltimatE Wrangler General Discussion 3 10-21-2008 07:00 AM
Blower motor resistor? crazbuck14 TJ Wrangler Technical Forum 0 12-06-2007 03:05 PM
blower motor resistor $$$$$ mudluva TJ Wrangler Technical Forum 6 02-27-2007 12:51 PM
