blower motor current draw - JeepForum.com
post #1 of 4 Old 08-21-2007, 09:49 PM Thread Starter
Jackle
does anyone know how to test if the blower motor for the vents is drawing too much power....... basically how do i test its current draw and what should the spec be?
Jackle is offline
post #2 of 4 Old 08-21-2007, 09:55 PM
EG00TJ
EG00TJ's Avatar
1993 XJ Cherokee
voltmeter .....
96 ZJ Longarm
Previous rigs : 96xj , 92 xj , 00 tj , 90 xj , 93 Longarm XJ
EG00TJ is offline
post #3 of 4 Old 08-25-2007, 08:35 AM Thread Starter
Jackle
yea i know a voltmeter.......actually i just want to know the procedure (like speed switch on low or high or what) and what the spec should be
Jackle is offline
post #4 of 4 Old 08-25-2007, 09:33 AM
Texan4life
If you have an amp clamp, you can just clamp it around the blower power wire for a measurement. Using a multimeter to measure current requires that you break the circuit and put the meter in series with the blower motor.
I don't know what the amperage should be. It is fed from a 40A fuse through the blower motor relay, but it won't be anywhere near 40A. I'd guess between 15 and 20 amps.
Texan4life is offline
If it's not my blower motor resistor, it's my what??? blower still doesn't turn on.. bortz1892 TJ Wrangler Technical Forum 13 08-02-2010 09:13 PM
AC Blower Motor Williams YJ Wrangler Technical Forum 12 05-06-2010 09:00 PM
blower motor red_90 YJ Wrangler Technical Forum 4 08-18-2008 10:57 AM
Blower Motor - Ultimate fix ?? What's the amp rating on the motor? kingsqueak TJ Wrangler Technical Forum 34 03-15-2007 11:13 AM
Blower Motor sgtbak TJ Wrangler Technical Forum 6 10-03-2005 10:20 PM
