Quantcast Blower fan speed(s)?! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Blower fan speed(s)?!
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comPoison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.
Old 11-15-2007, 06:26 PM   #1
live2hunt
Fan only works on the high setting. None of the slower fan speeds work.
Is this the switch itself or the blower relay ubder the glove box?
'97 Wrangler SE / TJ / 2.5L / Auto Trans
live2hunt is offline   Reply With Quote
Old 11-15-2007, 10:13 PM   #2
brunosplace
Web Wheelin'
brunosplace's Avatar
the resistor.
search is your friend!! : http://www.jeepforum.com/forum/search.php?searchid=1552357
Originally Posted by Boodyrider View Post
Big tires, done right, are FREAKING EXPENSIVE. Deal with it, or don't go there.
Originally Posted by woodnjeep View Post
I live in the land where they salt cure roadkill.
97 Jeep TJ Sport, 4.0L, Auto, 3" BDS Lift (SOLD)
98 Jeep ZJ Laredo 4.0L, Auto, Stock for now. Totaled :-( Parting Out
96 Jeep XJ Sport, parted out and scrapped
Tummy Tuck without a body lift. Finished!!
brunosplace is offline   Reply With Quote
Old 11-16-2007, 05:47 AM   #3
live2hunt
And I love search . . . I really do.
But it doesn't like me.
Thanks anyway.
Keep the dirty side up!
Old 11-16-2007, 11:01 AM   #4
live2hunt
Replaced the resistor . . . still only blows on HIGH!
Old 11-16-2007, 12:00 PM   #5
Jerky bump
Oh, man, I'm going to pick up a resistor for mine tonight. I was betting that's what it was. I read some others having fried wiring- I hope that's not it.
Jerky bump is offline   Reply With Quote
Old 11-16-2007, 12:12 PM   #6
skeebs
skeebs's Avatar
same here, I got the HIGH only, hoping it's just the resistor. I don't have time for problems this weekend......or any weekend in fact.
skeebs is offline   Reply With Quote
Old 11-16-2007, 01:09 PM   #7
young yeller
had the same problem with mine little over a year ago- it was in the switch itself and i'm told it's actually quite common. all you have to do is pull the switch assembly apart and bend the little connectors back out a bit. what happened with mine was that over time the strikers (or whatever they're called) behind the dial inside the switch mechanism bend away just a little, losing their contact. it's kind of a pain in arse getting the switch apart, but i'm guessing your problem is in fact the same mine was. mine went from only having settings lowest and full (2nd and 3rd stopped working), to only full, then nothing. bent the connectors and now every setting works like new.
half hour of your time vs. having the shop tell you that you need an entire unit replaced...
2001 TJ Sport-Yellow l 4.0L/5sp
Yellow Jeep Club Member #5
young yeller is offline   Reply With Quote
Old 11-16-2007, 03:24 PM   #8
Jonny Jeep
Jonny Jeep's Avatar
Wiring changed in newer models but 97-99 might be the 20A fuse behind the glove box. High speed is supplied by a fuse in the underhood pdc.
"Giving English to an American is like giving sex to a child. He knows it's important but he doesn't know what to do with it."
Adam Cooper (19th century)
Rockauto 5% discount code can be found here... http://www.markviii.org/LOD2/products_services.htm
Online factory service manuals can be viewed at http://www.jeep4x4center.com/knowledge-base/index.htm#service
Parts list PDFs available from http://www.berrysprinter.com/jeepparts.php
Jonny Jeep is offline   Reply With Quote
Old 11-19-2007, 06:04 AM   #9
Jerky bump
--Don't know if I just got lucky-- it was the resistor--(pack?) hmff. electronic piece of plastic. It was covered in condensation and the front left edge was split open and you could see the corrosion pushing it's way out.
Someone a while ago suggested running the fan on normal to dry up the internal parts before shutting it off. I'm going to do this too.
--And what a spot to get at.
Glock Forum
