Quantcast Blower Fan out on one speed only...?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Blower Fan out on one speed only...??
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 07-20-2005, 07:22 PM   #1
SniperPilot
OK, this is wierd-ing me out: I was driving home from New Jersey with the AC going, and noticed a burning-rubber kind of smell coming from the vents...after a while it went away, but the next day, the fan speed selector switch on the heater/AC panel will work in positions 1, 2, and 4, but not position 3...it stops blowing completely when I set it on that position, no matter if it's on AC, heating, or defrost...
Anyone have this happen or know what the deal could be? I'm stumped (and it's probably something I should already know, so I apologize in advance for my nube-ness!)
Thanx!!!
SniperPilot is offline   Reply With Quote
Old 07-20-2005, 07:39 PM   #2
grinwa
Maybe the resistor pack or could be the switch itself. More than likely the resistors. Check around with a multi meter. I think the resistor pack is pretty cheep. Jerry might pop up and tell you about how much they run. Good luck.
Greg
'99 TJ
Experience is something you don't get until just after you need it.
grinwa is offline   Reply With Quote
Old 07-20-2005, 07:42 PM   #3
TJ Toy time
I had the same problem. It's the fan resistor module. And it's covered under the waranty. HTH
2003 LKM WRANGLER SPORT
STEVESJEEPFAB.COM Front and rear bumper w/swing
IPF J-01 Dual beam Driving/Fog lamps
AR 767 15x8
XM Satalite
Wet Okole's
Uniden CB w/firestick
3" Teraflex
Rancho RSX Shocks
Rancho Stablizer
32"X11.5" Goodyear MTR
AA SYE
Tom Woods CV Drive Shaft
Spyder Coustoms Rockers
TJ Toy time is offline   Reply With Quote
Old 07-21-2005, 04:02 PM   #4
lupinsea
Same problem, too, but with fan position 2 and 3 out.
Anyone know where the fan resistor module is located? I heard it's under the dash on the passenger side. Is it in this location for all TJ's or just for a particular model year range?
- Jay
lupinsea is offline   Reply With Quote
Old 07-21-2005, 04:12 PM   #5
fergyfer
Usually when the resistor pack goes out, the fan will only work on position 4 (the only position that bypasses the resistors). When mine did this a couple weeks ago, it only worked on position 3, so I pulled the switch panel out of the dash and sure enough, the plastic was melted around several of the pins on the back of the switch (probably what you smelled) which I replaced for $30 at my dealership and fixed it.
Your resistor pack is behind the glove box, just below the area you can see through the glove box hole in your dash. But again, I doubt it is your resistor pack. Just my guess...
Green 99 Sahara
OME 2.5", JKS Discos, 31" Dayton Timberline MT's
IPF/PIAA Headlight Conversion
[URL=http://www.281.com/fergy/jeep/]My Jeep[/URL]
fergyfer is offline   Reply With Quote
Glock Forum
