Quantcast blower dosent work on defroster settings - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > blower dosent work on defroster settings
Truck-Lite's New LED Headlamp SeriesNEW! Poison Spyder RockBrawler BFH Bumpers!Poison Spyder BFH Rear Bumpers
Old 09-23-2008, 05:45 PM   #1
bulldogg
well my blower works on all settings and speeds except when I set it to defrost then it will not blow at all I searched and search but came up empty I believe it is an electrical problem...... any ideas
Bulldogg
bulldogg is offline   Reply With Quote
Old 09-23-2008, 05:46 PM   #2
HipCheck_1
http://www.jeepforum.com/forum/f9/all-settings-heater-ac-fan-blow-only-through-defroster-527339/
05 Jeep Wrangler 2.4l 4 cylinder
3" SL, 2" BL, 33 Eng belly up, 33x12.5 Pro comp MT
Low Ouput 4-cyl Jeep club member #151
HipCheck_1 is offline   Reply With Quote
Old 09-23-2008, 11:44 PM   #3
bulldogg
thanks for the link, but thats not my problem, all positions work, air blows out of all positions except defrost. in the defrost position the blower motor wont blow, so i leave blower on hi and go through all positions and it works, when I get to defrost the blower motor shuts off......
if vacum controls the blower motor then that thread helps but im sure my motor is electrical.... not trying to be a smart *** just frustrated....when I search all i find is vacum related and default to defrost threads
thanks
Bulldogg
Old 09-24-2008, 05:01 AM   #4
Skyryder
Semper Fi
Skyryder's Avatar
You don't say in your profile what year, etc of jeep you have so I'm only guessing, but on mine the lever that controls which operation has an "off" function to the far left. Again guessing, the slider control is somehow thinking it's off while in the defrost position. Might be a simple fix as in cleaning contacts on the slider switch ?
Skyryder
'97 Black TJ - 4 banger - 5 speed
Proud user of the "K.I.S.S." Principle.
Black Jeep Society #264
Skyryder is offline   Reply With Quote
Old 09-24-2008, 10:04 AM   #5
bulldogg
oops.... I didn't specify did I, its a 2001 tj the blower switch is brand new
so I'm pretty sure that's not it.
bulldogg
Old 09-24-2008, 11:17 AM   #6
HipCheck_1
With the additional clarification of your issue you are right that link won't help.
Good luck.
Old 09-25-2008, 05:26 PM   #7
bulldogg
back to top......
Glock Forum
