Blower does not work on high - JeepForum.com
post #1 of 21 Old 05-06-2011, 06:33 PM Thread Starter
josh_br
2003 WJ
In my 1997 Wrangler, the heater blower fan does not work on high. It works on speeds 1-3, but when I switch it to high it kicks off. I have heard of this happening, only backwards, and the resister being the problem. But I have not heard of the problem happening this way. Does anyone have any ideas? Thank you!
Josh_Br
2003 WJ (Laredo), 1990 Toyota pickup
Used to have a couple TJ's and ZJ's
josh_br is offline
post #2 of 21 Old 05-06-2011, 06:40 PM
AntiPrius
Mine was acting like that too. I had to buy a whole new switch from the dealer, but I don't think it was all that expensive. Mine was melted some on the back side. If yours is, you'll probably need to replace it.
I found out for sure it was the switch by removing it and jumping a wire to all of the speeds on the back of the connector and they all worked, so I knew it was the switch.
AntiPrius is offline
post #3 of 21 Old 05-06-2011, 06:51 PM
97tjtom
check for this on the back of your blower motor on the passenger side footwell. i ended up cutting a connector from a junk yard tj.
Current: 1999 TJ 4.0 5 Speed
Past: 1999 XJ 4.0 Auto, 1993 XJ 4.0 5 Speed, 1997 TJ 4.0 5 Speed, 1994 XJ 4.0 5 Speed, 1993 Cadillac Sedan Deville 4.9L V8, 1991 Isuzu TrooperII 2.8L 5 Speed
97tjtom is offline
post #4 of 21 Old 05-06-2011, 09:54 PM
2003X
Its your "blower motor resistor". It needs to be changed. Its not hard to do, but its a PITA.
My Build
2003X is offline
post #5 of 21 Old 05-06-2011, 10:14 PM
AntiPrius
Mine acted similar and it was the switch assembly, not the resistor. Like I said earlier, just pull the switch assembly out, disconnect the connector on the back and use a wire to jump from ground to each wire (speed). If they all work, it's the switch. If they don't, it's probably the resistor.
post #6 of 21 Old 05-06-2011, 10:35 PM
freeskier93
It's not the resistor, the resistor only controls settings 1-3. Check the dash switch and relay.
freeskier93 is offline
post #7 of 21 Old 05-06-2011, 10:37 PM
Curly5759
Check the 40a fuse (#11) in the PDC under the hood, and the blower relay mounted on the a/c box under the dash. Both are used for High blower speed only. Lower speeds use fuse 8 in the fuse block.
If the connector for the switch is melted, it could be a sign that the fan motor is drawing too many amps and is close to the end of its life. I'd replace the connector and have the fan motor amp draw tested.
Curly
I start what I finish!
77 Jeep Cherokee S
97 Jeep Wrangler
Curly5759 is offline
post #8 of 21 Old 05-07-2011, 06:44 AM Thread Starter
josh_br
2003 WJ
All fuses are ok, but thanks Curly. Let me do some testing at the switch, see if the switch is bad. Like Freeskier93 said, I think when the resister goes back, settings 1 - 3 do not work but 4 does work. I'm having just the opposite. I don't believe the resister comes in to play on setting 4; I think it just lets the fan full-power. Maybe it's something with the switch or wiring. When I switch it to 4, I can hear the relay click off.
Thanks all; I'll try to let you know how I make out.
Josh_Br
josh_br is offline
post #9 of 21 Old 05-07-2011, 07:39 AM
micklock
Mine did the same thing, if I pushed in on the switch high would work. I got a new switch for 24$ from a dealership and it's been working fine for a couple years now.
micklock is offline
post #10 of 21 Old 05-07-2011, 08:56 AM
77midget
I don't think it is the blower resistor, and here's why. I have a melted resistor harness clip just like pictured above, and a bad resistor switch. The resistor switch knocks out speeds 1-3 when dead. Mine is not even plugged in right now, as I have not re-wired it or replaced the resistor. My High speed works fine.
without looking at the diagram, I think the way it works is that the switch supplies direct current to the motor on '4', but shunts it though the resistor for 1-3. based on the wire feed for the motor, which i also checked, this seems to make sense.
77midget is offline
post #11 of 21 Old 05-07-2011, 11:11 AM
Curly5759
The switch activates a relay in position 4 (high), the relay feeds the blower off of a 40 amp fuse in the PDC, seperate from the fuse for the lower speeds.
Curly
77 Jeep Cherokee S
97 Jeep Wrangler
post #12 of 21 Old 05-07-2011, 01:50 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
The HVAC switch supplies resistive ground, not power for the blower motor in positions 1, 2 and 3...
Knuckelhead is offline
post #13 of 21 Old 05-07-2011, 03:40 PM
2003X
I beg to differ.
My Build
2003X is offline
post #14 of 21 Old 05-07-2011, 04:21 PM
77midget
ahh. a more correct way of phrasing it. thank you Knuckelhead.
77midget is offline
post #15 of 21 Old 02-08-2013, 09:27 AM
autopc25
I was told by the dealer the switch is not available. They said it was part of the entire control. Do you have A/C? Do you have the part number?
autopc25 is offline
Blower switch does NOT work on high setting? clearedhot1 TJ Wrangler Technical Forum 21 11-08-2015 07:25 PM
ac blower does not work on high gerrymurphy YJ Wrangler Technical Forum 6 07-01-2010 07:28 PM
Heater blower motor won't work on high micklock Wrangler General Discussion 0 01-20-2009 11:28 AM
Blower has low and high only DRM-2000 Wrangler General Discussion 7 12-05-2008 09:23 PM
Blower Fan High Only jeep_mike TJ Wrangler Technical Forum 7 04-07-2005 06:49 AM
