Blinker turns on when braking?? - JeepForum.com
post #1 of 10 Old 08-23-2013, 10:23 PM Thread Starter
mikedff23
Any clue? I'm assuming I have a short but I'm not sure where I should start looking.
mikedff23 is offline
post #2 of 10 Old 08-24-2013, 08:56 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That is caused by a lazy turn signal switch not quite returning all the way back to center after completing a turn. A slight nudge of the turn signal towards its center position will stop the turn signal light from illuminating when you step on the brake pedal.
Replacing the turn signal switch is the permanent fix.
Jerry Bransford is online now
post #3 of 10 Old 08-24-2013, 10:31 AM Thread Starter
mikedff23
*smacks head* I've replaced the turn signal x3. Normally it was just getting stuck on. Now when I hit the brakes. The left side indicator flashes everytime I hit the brakes.
post #4 of 10 Old 08-24-2013, 10:49 AM
sc00bz
This. Mine has done the same thing for a couple of years and a slight nudge up will stop it until I utilize the left turn signal again.
Sent from my GSIII using HeepForum
97 TJ with some stuff.
sc00bz is offline
post #5 of 10 Old 08-25-2013, 08:08 AM
LubbTJ
Same problem with mine.. however mine doesn't do it every time.. seems to happen more often when it's really humid out, or it's just rained. I'm guessing the moisture creates a contact issue.
LubbTJ is offline
post #6 of 10 Old 08-25-2013, 09:37 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Multi-function switch.Buy a better quality one.
TheBoogieman is offline
post #7 of 10 Old 08-26-2013, 07:04 PM
steelslinger
I had my signal indicator light up on my gauge cluster when I turned the headlights on only when it rained. My left front signal lens was getting water in it shorting the marker to signal circuit. Check your tail lamps bulb contacts for rusty appearance.
steelslinger is offline
post #8 of 10 Old 06-19-2017, 12:36 PM
DstroyrOfWrldz
Does your left turn signal work while you're on the brakes with this issue? Mine stops clicking and both front and rear left turn signals light up solid when I brake.
Sent from my SAMSUNG-SM-J320AZ using Tapatalk
Joe
1999 Wrangler Sahara
2005 Wrangler Unlimited (Sold 9/2012)
DstroyrOfWrldz is offline
post #9 of 10 Old 06-19-2017, 12:45 PM
DylanC7410
Mine does the same thing every now and again...haha I thought it was my jeep lol I just nudge it everytime it happens...I have high quality metal cloak led signals and thats when it first started happening which was right after i replace my stock fenders to metalcloaks with their signals,....
DylanC7410 is offline
post #10 of 10 Old 06-20-2017, 10:19 AM
DstroyrOfWrldz
Yeah, nudging it works when I'm not using the turn signal, but when I am using it, nudging it would be turning it off. So when this is happening, my left turn signal doesn't flash if I'm using the brakes, it's just on solid.
At first I thought it was a grounding issue so I cleaned up and reinstalled the taillight screws, and I thought it was fixed for a couple of days but then it started again.
Joe
