Blend Door Repair - JeepForum.com
post #1 of 10 Old 12-25-2010, 04:54 PM Thread Starter
Parrishjeep
Blend Door Repair
Hi everyone, I was wondering if anyone has a write up hopefully with pics for replacing the Blend Door for my heat / AC, It has come detached, I am assuming I am going to have to pull the dash off although I am hoping that there is a way to do it without pulling the dash, Thanks in advance for the help and Merry Christmas
Parrishjeep is offline
post #2 of 10 Old 12-25-2010, 04:57 PM
1jack5
On a TJ? You are probably talking about a WJ (Grand Cherokee) correct? There has been many problems with the Limited WJ's having that problem.
1jack5 is offline
post #3 of 10 Old 12-25-2010, 05:05 PM Thread Starter
Parrishjeep
Sorry, I forgot to mention I have a 99 wrangler 6cyl with AC Automatic, Thanks again
post #4 of 10 Old 12-25-2010, 05:14 PM
1jack5
O ok, Some say you can go through the glove box but don't recommend it. In all honesty pulling the dash isn't that hard at all.
This should help too.
http://www.jeepforum.com/forum/f9/ho...repair-464741/
1jack5 is offline
post #5 of 10 Old 12-25-2010, 05:26 PM
Cuder
See if this thread helps you.
http://www.jeepforum.com/forum/f9/c-...vents-1088035/
My Build Thread:
Cuder is offline
post #6 of 10 Old 12-26-2010, 06:13 AM
timithye
I have no issues with getting heat from the vents, dash or floor, but when I have the vents or just floor selected and go up a hill, all the air goes comes out the dash onto the windshield, until I have leveled out. I am thinking vacuum leak or something of the sort. This problem has only been happening since having the heater core replaced.
Thoughts?
timithye is offline
post #7 of 10 Old 12-26-2010, 06:42 AM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Is the blend door on the 99 vaccum acticated? I thought it used the small motor in the passernger footwell.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #8 of 10 Old 12-26-2010, 07:46 AM
LalanP111
not sure about the 99 but 98 still used vacuum.
IMHO the dash isnt that hard to pull however it is a lil tricky and at times frustrating.
if it is a vacuum then you can just look under the dash as you can see all the levers easily. try to move the arms of the vents that connect to the vacuum cylinders, you may have a broken one.
1998 TJ, 4.0L, RC 2.5", 31x10.5-15 Duratracs (sold)
1988 MJ, 4.0L ..soon for be on 33's and 6.5" LA/SOA (project)
2004 TJ, 4.0L, Columbia Edition, 2.5" Rough Country, 33x12.5-15 Duratracs, Quadratec Winch, Dual Top (DD, future project)
Originally Posted by Knuckelhead View Post
It takes care of me and in return, I take care of it. Takes me away from everything I don't want to be around, and back again when needed...
LalanP111 is offline
post #9 of 10 Old 12-26-2010, 02:52 PM Thread Starter
Parrishjeep
Blend door is actuated by a motor electrically which works fine on my 99, The door is broken and needs to be replaced, I appreciate the help
post #10 of 10 Old 12-26-2010, 03:05 PM
jeepwrangler97
They sell the plasic part that go into the HVAC housing that connect to the arms, but the newer motor actuator you have, is the plastic part at the bottom of the door broken, you could try to find the piece, but I'm not sure if the dealer sells the door without the housing.
Also where are you in FL? if you need help taking out the dash, if your real close I could help if needed, I just had my dash out a few months ago.
jeepwrangler97 is offline
Hot Air Again! Blend Door Actuator Repair Savvy TJ Wrangler Technical Forum 41 10-26-2016 01:26 PM
Blend air door help RockRodHooligan TJ Wrangler Technical Forum 15 12-30-2011 03:47 AM
Need to get to blend Door footman TJ Wrangler Technical Forum 5 10-20-2008 03:27 PM
Blend Door Problems skatedork TJ Wrangler Technical Forum 1 12-12-2007 08:49 AM
Blend Door bobqwerty TJ Wrangler Technical Forum 5 06-24-2005 09:10 PM
