Quantcast Bleeding clutch slave - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Bleeding clutch slave
Old 08-27-2006, 07:30 PM   #1
hol
After replacing my clutch this weekend on my '02 I noticed on the slave cylinder there does not appear to be a bleeder valve. Am I overlooking something or is there some other way to bleed the system?
-Thanks
2000 Sahara, 33x12.50 BFG AT's, Black American Racing steel rims, 4" BDS lift, Warn XD9000i, Custom Front bumper, Blue Ridge Offroad Rock Rails, Warn swing away tire carrier, 4to1 transfer case, many other odds and ends.
www.teamoneexhibits.com
hol is offline   Reply With Quote
Old 08-27-2006, 07:31 PM   #2
Rocky529
Jeep
Rocky529's Avatar
No, you are not overlooking anything. The system is closed, no need to bleed it.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 08-27-2006, 08:53 PM   #3
hol
How do you build pressure back up in the system?
Old 08-27-2006, 11:10 PM   #4
Wooders
1975 CJ6
"Closed"?
Sorry I'm curious to what you mean by "closed".
You can indded get air into the system and it can require "bleeding" - but this is done by opertaing the slave piston by hand which will self bleed back to the resivour - unless the slave is damaged or worn letting more air in.
There is a small grub screw on many slave housings this should NOT be touched.
Sorry if you search for this it has been explained several times.
Cheers
Cheers
Wooders
Sydney Jeep Club
Wooders is offline   Reply With Quote
Old 08-28-2006, 10:15 AM   #5
hol
The search doesn't work for me. Thanks for the tip, that worked great. I got the pressure built back up.
Glock Forum
