Blank, aluminum full corners for an LJ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Blank, aluminum full corners for an LJ?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBill Baird Motorsports DIY parts - NalinMFG.comComponent speaker deal for your dash - NalinMFG
Unread 07-23-2014, 10:14 AM   #1
pcoplin
I'm looking for the cheapest 6061 corners for my TJ. I need LJ length to cut down (or 8 inches longer than a TJ). I'm going to cut them up so bad I'd rather not spend $600 on a set. Even 1/8 6061 would be fine.
THese are about the most inexpensive I've found, but shipped will still be $500.
http://www.stoutfabrication.com/Alum...ards-set-of-2/
Savvys are $550 plus shipping.
Maybe someone sells just the "trail" corners in aluminum, and I can weld on some sides from flat aluminum?
Any ideas? Thanks!
98 TJ 5.9/46RE/D300
85 Wagoneer 5.2/44RE
01 F250 Powerstroke 7.3/ZF6
Ultra4 KOH #689 car
pcoplin is offline   Reply With Quote
Unread 07-23-2014, 10:18 AM   #2
dayriesw
dayriesw's Avatar
Try moab 4x outpost. You will have to call for pricing.
Impact Orange LJ - DD...sitting low, flat bottomed, fully armored and locked on 37s
dayriesw is offline   Reply With Quote
Unread 07-23-2014, 10:43 AM   #3
pcoplin
Good deal, thanks. I called Steve there and he's pricing out a corner made from 1/8 6061 custom made to my specs. Spending the cash for one that I don;t have to modify might be worth it.
98 TJ 5.9/46RE/D300
Ultra4 KOH #689 car
