Black Magic Brakes and RCV COMBO!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Black Magic Brakes and RCV COMBO!!
Labor Day Sale!FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitEngo winches available at www.rockridge4wd.com! Free shipp
Unread 06-13-2014, 09:02 AM   #1
Garza
Vendor
Garza's Avatar
We at 4LowParts had the opportunity to install the 1st VANCO DUAL Mode 15”/16″ Big Brake Kit w/Black Magic Brake Pads and RCV axles!
1st step is to obviously do away with the puny stock stuff!
I took them down to a bare inner C. While this is not necessary, it is a great opportunity to change ball-joints if yours are in need of replacement. We chose to change them to new Spicer ball joints.
Without further delay......here is the part that makes this all come together! These are the NEW MADE IN USA Dual Mode knuckles for the 15"/16" Big Brake kits!!
Me in amazement of the coolness!!
'05 LSJ
www.4lowparts.com
Black Magic Brakes
Garza is offline   Reply With Quote
Unread 06-13-2014, 09:02 AM   #2
Garza
Vendor
Garza's Avatar
Now, lets get those RCV axles in there!
Boot fits perfectly through there (it doesn't have to obviously) but just to show.
I chose to do it this way just to know it could be done. Otherwise holding the boot behind the knuckle works too.
Like a glove!!! Now you can install the dust shield, and I chose to use NEW Timken unit bearings, if yours are fine..no need to do this!
The RCV's fit PERFECT!!
'05 LSJ
www.4lowparts.com
Black Magic Brakes
Unread 06-13-2014, 09:03 AM   #3
Garza
Vendor
Garza's Avatar
And of course the BRAKES!
Now, here is where this gets cool!! This is the 16" BBK, so you install the caliper saddle in the rear-most dual mode holes on the new knuckle!!
Now get the abutment clips and BLACK MAGIC brake pads in there!!
Perfect fit and alignment, the way it should be!!
NOW time for the NEW! not re-manufactured corrosion resistant Zinc Plated 48mm dual piston Calipers!!
And finally, after connecting the brake lines and double checking everything....BAM...a beautiful combo!
'05 LSJ
www.4lowparts.com
Black Magic Brakes
Unread 06-13-2014, 09:09 AM   #4
Tonellin
All that work and you still hand the caliper by the brake line?? haha just breakin balls...
This is very cool...not on my immediate mod list but definitely in the near future this setup is ideal
06 LJ Rubicon
http://www.jeepforum.com/forum/f22/lj-rubicon-build-1481013/
Tonellin is offline   Reply With Quote
Unread 06-13-2014, 09:17 AM   #5
Robert J. yates
A nice example of an innovative part that serves a great purpose.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline   Reply With Quote
Unread 06-13-2014, 09:23 AM   #6
Cavasar
Oooh good news for me. Just got my RCVs on and have been wishing I could still do BBK. Funds are low now but this should be in the future.
Cavasar is offline   Reply With Quote
Unread 06-13-2014, 09:35 AM   #7
Garza
Vendor
Garza's Avatar
Thanks!, and we have these in stock!
One thing I should mention is that the new knuckles are ABS compatible!!
'05 LSJ
www.4lowparts.com
Black Magic Brakes
Unread 06-13-2014, 09:42 AM   #8
tjMtl
Great pics. I noticed the hanging caliper as well, but it wasn't being reused, nor was the brake line.
tjMtl is offline   Reply With Quote
Unread 06-13-2014, 09:44 AM   #9
biffgnar
biffgnar's Avatar
Nothing wrong with hanging the caliper by the brake line even if all being reused.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote
Unread 06-13-2014, 09:53 AM   #10
NIB-98TJ
1) Will the new knuckles work with a Dynatrac Pro Rock 44 & RCVs?
2) The new knuckles look beefier/stronger than the stock knuckles. Is that the case?
3) I assume the 16" brake package requires 16" wheels and won't work with 15" Allied beadlocks?
Thanks,
NIB
98 TJ, 4.0, 5 spd, 1" MM, 1" BL, RE 4.5" LA's, 36" TSL-SX's, D30/D44, ARB's, Atlas 4.2, etc
NIB-98TJ is offline   Reply With Quote
Unread 06-13-2014, 10:42 AM   #11
Garza
Vendor
Garza's Avatar
Originally Posted by NIB-98TJ View Post
1) Will the new knuckles work with a Dynatrac Pro Rock 44 & RCVs? As long as the Inner C is the "stock" size, then yes (most of them are, but only you and Dynatrac know your axle specs. I would say it is safe to assume so if you can buy off the shelf stock size ball-joints, wheel bearings and current replacement brake parts)
2) The new knuckles look beefier/stronger than the stock knuckles. Is that the case? The new knuckles are high strength nodular iron, spec to oem tolerances, with the new dual mode features.
3) I assume the 16" brake package requires 16" wheels and won't work with 15" Allied beadlocks? The COOL thing about this kit is that you can order it without rotors. You mount the caliper up and then test fit your wheel. If it fits in the 16" location knuckle hole, perfect, order the 16" kit rotors. If it doesn't, get the 15" kit rotors and move the calipers to the forward hole. The only difference in the 15" and 16" kit is the rotor size!
Thanks,
NIB
Thanks! RG
'05 LSJ
www.4lowparts.com
Black Magic Brakes
Unread 06-13-2014, 10:45 AM   #12
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Unlimited04 is offline   Reply With Quote
Unread 06-13-2014, 11:34 AM   #13
clg82
clg82's Avatar
my thoughts exactly.....how much is this going to lighten my wallet was my second question...
Drink some bleach.
clg82 is offline   Reply With Quote
Unread 06-13-2014, 11:38 AM   #14
Tonellin
About 2g's if you get the brake/rcv combo but I think if you click on their website their is some special limited time rebate available. I'm not sure if that's factored into the price that I got when choosing my combo or if they add the discount later
06 LJ Rubicon
Unread 06-13-2014, 11:43 AM   #15
clg82
clg82's Avatar
so that includes the rcv shafts, big brake kit and rotors and pads?! that's not too bad at all.....thought it would make me lighter lol
Drink some bleach.
