Black Bart- Clutch Issues - JeepForum.com
post #1 of 3 Old 12-15-2014, 02:51 PM Thread Starter
papa1961
I recently put a new clutch (Centerforce II) in my 2006 TJ Rubicon. Now at least once a week I will have trouble getting in to gear (while jeep is running). If I turn off the jeep, slides right in to gear. It acts like the clutch is not disengaging (with jeep running, when I try to put in gear jeep will lurch forward). Last week I replaced the slave cylinder and the same thing. Clutch/ Master cylinder? Anyone have any ideas?
papa1961 is offline
post #2 of 3 Old 12-15-2014, 03:45 PM
JFM626
JFM626's Avatar
So most of the time it is fine? When it doesn't work have you tried rapidly pumping the clutch pedal to see if that helps? Are you finding this happens just when you are going into gear after a stop or also when shifting through the gears? When it doesn't work does the pedal feel mushy with no resistance for the first few inches of downward travel?
How can you trust an atom, they make up everything
JFM626 is offline
post #3 of 3 Old 12-16-2014, 06:14 AM Thread Starter
papa1961
BB-Clutch Issues
Petal feel good/normal. It started when I was stopped, but now it can happen when I am driving. There are no noises or chatter.
papa1961 is offline
