BL / MML combo without shifter problems - JeepForum.com
post #1 of 5 Old 01-31-2007, 04:54 PM Thread Starter
GringoLoco
GringoLoco's Avatar
I know this has been asked over and over again, but I couldn't find it in the search, so, sorry.
I'm doing the FT 3" economy lift and want to do a 1 inch BL and 1 inch MML. So far my plans are a JKS 1.25" BL and M.O.R.E MML. The questions are:
1. I remember a while ago people were talking about some brand of BL requiring welding and/or cutting something, not being a perfect bolt on. Can't remember. Is the JKS good to go without extra work?
2. I know the MML is to fix the fan shroud thing, but will I have shifter or transfer case shifter problems running a transfer case drop, MML, and BL all at the same time? I know a transfer case drop at the same time as a body lift means shifter issues, is the MML enough to fix that?
Thanks.
YELLOW Jeep Club Member #5606
13 mpg - edit: 12 mpg
No hi-lift on the hood (yet)
Odd noises
Still can't get it to take off from a treadmill....
GringoLoco is offline
post #2 of 5 Old 01-31-2007, 04:58 PM
SecondTJ
SecondTJ's Avatar
there should be a transfer case level drop bracket.
no, a MML isn't enough to fix the shifter issue, the body will still "swallow" the shifter an inch
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #3 of 5 Old 01-31-2007, 05:31 PM
Brown Dog
Vendor
Brown Dog's Avatar
The MML does fis the fan shroud thing, but that is not a good reason to install one. It affects your driveshaft angle, and is used to help correct the angle after lifting or mods. Please goe here and click on the links that are about halfway down the page.
http://www.browndogindustries.com/FA...ed_Questi.html
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #4 of 5 Old 01-31-2007, 05:41 PM Thread Starter
GringoLoco
GringoLoco's Avatar
Thanks for the read, learned a lot. So, should a 1" MML be enough to offset a 3" FT lift? I was under the impression that a MML definately helped with driveline vibes, but not enough on it's own.
Odd noises
post #5 of 5 Old 01-31-2007, 05:43 PM
SecondTJ
SecondTJ's Avatar
With a 3" lift, i dont think a 1" MML will be enough, i'd at least get a t-case drop just to have it if you do have vibes
SecondTJ is offline
4 wheel shifter problems???? krz-az TJ Wrangler Technical Forum 1 10-14-2007 08:46 AM
Shifter problems Rubicon153 TJ Wrangler Technical Forum 3 09-11-2007 04:57 PM
TC Shifter Problems JeepOX TJ Wrangler Technical Forum 5 05-24-2007 06:12 AM
Shifter Problems after BL and MML.... colbyB25 TJ Wrangler Technical Forum 10 01-18-2006 11:36 AM
Shifter Problems after bl and mml? aaronswb2 TJ Wrangler Technical Forum 2 10-03-2005 07:16 AM
