BL Body Lift install / Fan clutch / Motor Mount Lift sorta ... - JeepForum.com
post #1 of 4 Old 02-21-2011, 02:25 AM Thread Starter
Mike_Motorbike
I made a BL out of some " extra Plastic I had left over from making my own BB spacers.
http://www.jeepforum.com/forum/f9/ho...-pics-1025457/
and then added another 1" plus shocks vvv
http://www.jeepforum.com/forum/f9/ho...hocks-1114872/
I also made my own TC shifter bracket Had to make two because on the first one I only made it go 1" and it needed to be a minimum on 1-3/8" to clear all the brackets.
The body lift was easy to install. The shifter bracket was not.
I had to take the main bracket on the floor to get it all in.
I was going to make a MML too but the bolts are metric and I had gotten a 7/16" coupler bolt to use on the welded stud .... well I don't think I will be able to find a metric coupler bolt so I may have to .... BUY a MML ...
In the mean time I Had a hell of a time with the fan shroud I could not get it low enough to clear the fan .... AND I could NOT get the Fan Clutch Off to do any trimming....( Chipped a piece of the power steering pull trying)
so I lowered it as far as it would go.
THEN I made a little 1/4" MML spacer with some extra steel and bolted it on using the stock bolts.... now it clears the fan ....
I haven't been able to find a post talking about these issues to I just thought I'd share.
If you plan to do a BL without a MML try to take the fan clutch off first. Make sure you can or you have a big problem if you do it last like ME.........
$60 JKS http://www.store.jksmfg.com/merchant...ode=Body_Motor
$54.95 RC http://www.roughcountry.com/jeep_xtr...or-mounts.html
JEEPING .....The art of getting dirty and going broke while slowy heading nowhere and taking all day to do it.....
2001 TJ 31"s 4.0L Auto , Blue , Soft Top , Full Doors. Home made BB 1 3/4" front 1" back...quick discos
Mike_Motorbike is offline
post #2 of 4 Old 02-21-2011, 02:41 AM Thread Starter
Mike_Motorbike
With the 2-3/4" in front and the 2" in back BB and the 1" BL
I got 3-3/4" total in front and 3" total in back for $137.95 for the shocks plus like $20 for bolts
$157.95 total cheapest I could find for all that stuff would be $300.
post #3 of 4 Old 02-21-2011, 04:22 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
You NEVER take the fan clutch off to do a BL.A BL comes with fan shroud brackets to lower it or you simply drill new holes in the stock one.I bought a new BL and MML on craigslist for $60 for both.
TheBoogieman is offline
post #4 of 4 Old 02-21-2011, 12:33 PM Thread Starter
Mike_Motorbike
The fan shroud hit the lower radiator hoses and would not lower enough to clear the fan blades.
The directions I down loaded for BL's say you have to trim the fan shroud around those hoses.
To do that you need to remove the shroud and to do that you need to removed the fan clutch too.
Last night I read some other manufactures instructions and they say to lower the whole radiator with their supplied brackets.
Anyway if you are NOT going to do a MML you will probly have interference with the fan and shroud.
If the DIYer is going to do this at home be prepared to either remove the fan clutch or lower the rad OR put on a MML.
I have air conditioning so I may have to remove the motor mount bracket to the engine to be able to get the mount out.
Motor Mount and Body Lift install question LJ_Cool TJ Wrangler Technical Forum 11 06-22-2009 02:53 PM
Motor Mount Lift + Body Lift = Radiator Shroud Placement? tommanns YJ Wrangler Technical Forum 6 01-26-2009 08:04 PM
Body Lift and Motor mount lift questions RYANR97 TJ Wrangler Technical Forum 12 08-31-2008 01:31 PM
1" Motor Mount Lift w/o Body Lift? Sport014 TJ Wrangler Technical Forum 11 07-24-2007 11:12 AM
Best 1" Body Lift and Motor Mount Lift? Stricken TJ Wrangler Technical Forum 18 05-11-2004 02:13 PM
