BL With An Auto Trans - JeepForum.com
post #1 of 12 Old 01-06-2007, 10:51 PM Thread Starter
treehugger
I just got an 04 Rubi a couple days ago and my mind is already thinking MODs . My question is with an auto transmission does a BL mess with the shifter linkage? I know on my TJ w/ a 5spd shifting into 2nd, 4th, & rev was affected.
Nothing left to do but smile mile smile....
2004 Rubi, Bright silver metalic., 2.5 OME HD, JKS adj track bars, JKS quick disco's, JKS 1.25 BL, JKS BMML, Rockhard 4x4 front & rear bumpers, Cobra 75 CB
treehugger is offline
post #2 of 12 Old 01-06-2007, 10:55 PM
Rocky529
Rocky529's Avatar
Just a 1" body lift should not mess with the linkage.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 12 Old 01-06-2007, 11:04 PM
harley_sr
Just got done with mine tonight, Works fine.
2000 Jeep Cherokee Classic
5.5 RE Lift
4.0L Auto
33's on 15x8's
harley_sr is offline
post #4 of 12 Old 01-06-2007, 11:28 PM
happycamper
1986 XJ Cherokee
mine works fine with the 1.25 bl
Gone but not forgot. 2000 Sahara 4.0, auto, 4"rock krawler x factor long arm, 33x12.50x15 M.T. Mtz, M.T. classic lock rims,30/44 limited slip, land runner safari rack, land runner front, and rear bumpers, warn 8000i winch, cobra cb, jks 1.25" bl, brown dog 1" mm lift.AA sye, J.E. Reel drive shaft, Aussie locker, Rock Crusher front cover
happycamper is offline
post #5 of 12 Old 01-07-2007, 02:36 AM
TexanTJ
2014 JK Wrangler
Mine works fine with 2" bl
hypothetically, the auto tranny shift linkage is long enough for a 4 or 5 inch bl (not that there is such a thing.)
you should have no problems with any size bl.
2014 JKU Sport - Wife's Mall Crawler on 35s. Badlands Winch, 2" Coil Spacers, 1" PA BL
1999 F250 7.3 - 290K Miles and Counting
"I am not going to censor myself to comfort your ignorance."
TexanTJ is offline
post #6 of 12 Old 01-07-2007, 06:05 AM
igofshn
Locked @ both ends
igofshn's Avatar
Shifter linkage is a cable. you can do any bl and not worry about it in reference to a auto.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #7 of 12 Old 01-07-2007, 11:20 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Like igofshn said, its a cable.
And the shifter is bolted to the body, so it goes up with the body lift.
You don't have to do anything.
Wheelin98TJ is offline
post #8 of 12 Old 01-08-2007, 12:49 AM
roadking
roadking's Avatar
Then, is it necessary to disconnect the shift linkage under the driver's side carpet before installing the body lift, or is that only for the manuals?
Gotten Savvy! Awaiting Tummy Tuck ;-)
65 million firearms owners killed no one yesterday - Assault is a behavior, not a device.
roadking is offline
post #9 of 12 Old 01-08-2007, 01:35 AM
Jeepin_Al
Just taking it easy!
When I did my BL on my 02 I didn't need to do anything but the pucks. It was a 1" lift and everything worked great (lucked out and didn't have to adjust the TC linkage either).
"rejected by the signature police"
Jeepin_Al is offline
post #10 of 12 Old 01-08-2007, 07:40 AM
igofshn
Locked @ both ends
igofshn's Avatar
The only linkage effected will be the tcase linkage.
igofshn is offline
post #11 of 12 Old 01-08-2007, 08:31 AM
dennisuello
dennisuello's Avatar
that would be t-case linkage and it's identical between auto and manual.
dennisuello is offline
post #12 of 12 Old 01-08-2007, 08:44 AM
Wrangler04for40
Wrangler04for40's Avatar
For me, its difficult to put it in 4 lo, but I think it was not so easy stock either. Maybe you should try 4lo a couple of times so you can tell if its any harder. Theres discussion on here of how to adjust the bar (linkage) if there is a snag. Also Advance Adapters makes a bracket for a fix. That said, I have an 04 Sport with a body lift, and I can get 4lo, but its work. I did put on the linkage bracket that came with the BL. (Teraflex) If those help or not is probably different between Jeeps, like so much else, its trial and error to get things right. Good Luck.
Jeep junky lookin for a fix...
Wrangler04for40 is offline
Is it easy to swap out my 3speed auto trans for the 4speed auto trans? bhicks TJ Wrangler Technical Forum 15 08-30-2010 09:30 AM
auto trans??? KenJ95 YJ Wrangler Technical Forum 6 09-15-2008 09:40 PM
auto trans - no 2nd CostaRicaJeep YJ Wrangler Technical Forum 3 08-15-2008 05:01 PM
What Auto Trans in 88 YJ 4.2 Richo YJ Wrangler Technical Forum 2 10-22-2007 04:09 PM
Auto Trans MTNMAN TJ Wrangler Technical Forum 10 06-02-2004 09:31 PM
