A bit of stuttering... - JeepForum.com
post #1 of 1 Old 06-17-2008, 06:45 PM Thread Starter
Hardtop99
When I fire up the TJ when the engine is cold I can drive with no issues. But if I stop for as little as 5 minutes and fire it back up, I can make it a couple of blocks then I get this odd bucking/ stuttering with the occasional backfire. It will last for only 30 seconds or so, then back to normal driving. Any ideas? I have already changed the TPS because it did go bad. And no warning lights or check engine light comes on while doing this. Its almost as if it were trying to run out of gas on me or some air got into the line. Remember, this only happens after the engine warms up and I stop for 5 to 30 minutes. Thank for your input.
Click on my profile for TJ specs.
Hardtop99 is offline
TJ Stuttering.. esad_b TJ Wrangler Technical Forum 36 08-23-2009 04:38 AM
2.5L stuttering at 50 MPH... burnz34 TJ Wrangler Technical Forum 1 08-02-2009 05:37 PM
Stuttering CALITJ TJ Wrangler Technical Forum 8 07-13-2008 11:46 PM
TJ stuttering Piratejonh TJ Wrangler Technical Forum 3 01-15-2007 04:16 PM
Stuttering hbmex858 YJ Wrangler Technical Forum 1 01-03-2007 11:12 PM
