Bilstein 5100 w/2.25" 4wc BB? - JeepForum.com
post #1 of 7 Old 07-29-2010, 09:40 AM Thread Starter
AntonioAndolini
2015 JK Wrangler
Searched up and down the forums, couldn't find an answer, or perhaps there's no answer. Looks like I'm going to go with the 4wc 2.25" BB.
The 5100's seem the best fit for what I'm trying to do right now, after reading probably every darn thread here on shocks (RE Monotube too stiff, Sky Hydro's too soft/poor QC sometimes, etc. etc.).
So my question is:
- 5100's for 0-1" of lift?
- 5100's for 3" lift?
- Neither?
The old conventional wisdom seemed to have been "Bilstein doesn't make a 5100 for <3" lift, look HD or another brand", until they came out with the 0-1" 5100's.
BB's, at give-or-take 2" lift depending on the brand, fall square smack dab in the middle of the 1" top end for the one shock and the 3" bottom end for the other shock. Do I have no options? Use the 0-1", since some people ahve used stock shocks with BBs?
Thanks for any help. Looking to purchase at payday tomorrow
AntonioAndolini is offline
post #2 of 7 Old 07-29-2010, 10:06 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Do you know the extended and collpased lengths of the Bilstein shocks you are considering?
If you can get this info, you can get a for sure answer.
I have never seen the specs on the 0-1" 5100 shocks.
The ones specified as fitting 3" of lift - do you have model numbers for those? I'm wondering if they are the same shocks that are often recommended for 4" of lift.
Wheelin98TJ is offline
post #3 of 7 Old 07-29-2010, 10:10 AM
APEDZ04LJ
well i just picked up bilstein 5100's for a 3" but the box says 4" on it, but im also running spacers so.....
APEDZ04LJ is offline
post #4 of 7 Old 07-29-2010, 10:22 AM
vohk
I have the bilstiens recommended for a 3" lift (check quadratec for the lengths; havn't measured myself to double check their numbers though), and I really wouldn't recommend them for a 2" lift. You won't have very much up travel.
Personally, I'd probably be looking at OME for something in the same price range and with a similar ride. Much better collapsed length for that application.
vohk is offline
post #5 of 7 Old 07-29-2010, 11:06 AM
drivermod
I have the 4" lift (I don't remember part #'s) Bilsteins and they were too long for my 2.5 OME lift. Only had about 2.5" of up travel. The next size down worked perfect and gave me about 4" of up travel.
drivermod is offline
post #6 of 7 Old 07-29-2010, 12:56 PM Thread Starter
AntonioAndolini
2015 JK Wrangler
Huh. Thanks to all of you.
Looking at the 2.25" 4wc BB, and all of the bad reviews re Skyjacker have me not feeling them. Also there were a number of bad reviews of the RE twin-tube, and twin tubes in general, and many people who use their TJ as a DD over 60-70% of the time or so seem to think the RE monos are too stiff.
post #7 of 7 Old 07-29-2010, 05:12 PM
drivermod
I love how the Bilsteins ride.
suspension , suspension lift , suspension set-up
OME or Bilstein 5100 akordboy TJ Wrangler Technical Forum 9 10-23-2010 07:23 PM
Bilstein 5100 digizure YJ Wrangler Technical Forum 3 03-09-2010 05:09 AM
Which Front Bilstein 5100 for RE 3.5" Keith_C TJ Wrangler Technical Forum 2 09-28-2009 04:39 PM
Bilstein 5100 are POS, what's next? GrimJeeper91 YJ Wrangler Technical Forum 3 08-02-2009 11:15 AM
Bilstein 5100 for a 06 Unlimited w/ 2" lift? okietom TJ Wrangler Technical Forum 6 03-16-2009 03:21 PM
