07-21-2003, 06:26 PM
#1
Are there many of you running these?
I managed to strip out the inner nut (seems kind of self-reflectory...) of the top hardware (just one), and I've heard the replacements are expensive, so thinking about going with the billet disconnects I saw at acmejeepparts.
First of all, how do you prevent this, and do you just have to drill the thing out to get it off?
Secondly, are the billets a good idea?
Thanks.
<>< KD ><>
What I Have: 1994 Grand Cherokee Limited
2.25" 4 Wheel Customs Spacer Lift
Cragar Soft 8's, High Tech Retreading OTR Muds, New Front End
What I Do: MT Web Guy
07-22-2003, 11:59 AM
#2
Anyone?
<>< KD ><>
07-22-2003, 12:09 PM
#3
Ok, you have two ways of fixing your problem:
1. Spend about $60 or so on the sun performance billet quick disconnects. I personally have these, but I bought them used (less $$$)and love them. The nice thing is that the ends are both straight instead of angled. Makes the top very tight and less noisy.
2. Spend about $5 at your local hardware store and have basically the same thing, but using your plastic stock ends. This will involved drilling out the ends so that can insert a pin. If you search this forum you will find a writeup on it somewhere. Think this was just recently discussed.
HTH!
Fred
Fred
JAFGJ
07-22-2003, 01:10 PM
#4
Thanks...
Just spent $6 at the hardware store, should work fine, and only requires drilling out the plastic and cutting the pins to fit. The billet ones look nice, but hey, $44 is $44, right?
<>< KD ><>
07-22-2003, 05:00 PM
#5
I agree with the plastics.
I have the billets (Christmas present) and I will tell you, since they don't give like the plastic ones (notice the plasic ones are bent a little?) the top is alway very tight. Nice, but a bear getting the hinges to hook when putting up the top. If I was old or weak or old and weak, I wouldn't be able to do it.............
2001 TJ Sport
Everything SELF INSTALLED.
The Serious Stuff:4.5 RE LA, 35" MT/Rs, 4.88s, Super44 w/Detroit, D30 w/Ptrax, SYE, Tera 4:1, 2LOW & Rear Disks, AntiRock, Lotsa Skids (some homemade!), Nth Shock Shifters, Patriot 9500...and LOTS more !
07-22-2003, 05:17 PM
#6
That's good to know. A new top is in the near future, so I don't need it to be any tighter than it already will be.
We'll see if I can drill these things out effectively, and I'll take some pics along the way.
<>< KD ><>
07-22-2003, 08:46 PM
#7
I just found ALL of mine stripped out, so I removed the brackets from the rollbar (after removing the soft top bars from the plastic disonnects via the small phllips screw). Then I drilled holes in the plastic pieces opposite the head of the torx head so they could be knocked out with a hammer and drift. Instead of billet disco's, I went to the hardware store and spent $3 for quick release pins to use with the original plastic discos.
"Laws that forbid the carrying of arms...disarm only those who are neither inclined nor determined to commit crimes...Such laws make things worse for the assaulted and better for the assailants; they serve rather to encourage than to prevent homicides, for an unarmed man may be attacked with greater confidence than an armed man."
--Thomas Jefferson
07-22-2003, 08:49 PM
#8
...I saw a goiod write up on this on JU one time I will go look for it...
in fact you can simply use small cotter pins the size of the bolt...
Smuggler Re-Born.....
