Bikini top wont fit/clip into door surrounds - JeepForum.com
post #1 of 13 Old 12-23-2009, 09:53 PM Thread Starter
scrnnmssuck
I just recently bought a best top bikini top for the jeep. I had a pair of door surrounds off a 98 sitting around. I wanted to eliminate the gap from the doors to the top, so i decided to put them on. It appears the top is to small across the jeep to fit. I can BARELY get them to snap in if i dont use the knobs to screw into the roll bar. Even then the top is pulling so hard onto the surrounds its pulls them towards the middle and is not sitting correctly. I even let the top sit our in the sun all day to get some more play or stretch out of it, but it didnt do much. I was thinking of maybe trimming the surrounds down but i dont think there is much to take off there. Im open to any suggestions.
scrnnmssuck is offline
post #2 of 13 Old 12-23-2009, 10:16 PM
Bishop Creek
Checking the date on this post...OK today, Dec. 23rd. Please tell me, what does warm sunshine feel like?
ďThis isnít the Old West, because the New West has never arrived. Itís just the West, like Wyatt Earp died yesterday.Ē
─ Michael Martin Murphey talking about the Eastern Sierra during an interview in 1996.
Bishop Creek is offline
post #3 of 13 Old 12-23-2009, 10:22 PM Thread Starter
scrnnmssuck
Feels like 70 and sunday. Cant say i miss the east coast one bit or the snow.
post #4 of 13 Old 12-24-2009, 12:41 AM
bmxrules39
I want my bikini back on
mine stretches REAL tight too. I found that if I put half the insert in the front half of the door surround on one side then go to the other side and put the insert into the back half of the surround then slowly work them til there all the way in it works best. Sometimes it takes a pair of channel locks to kind of pinch it along the way, after you get it started, but be careful not to mar the fabric or crack the insert. Also (obviously) lift up on the surround while you're pulling down on the bikini.
§wHitt§
bmxrules39 is offline
post #5 of 13 Old 12-24-2009, 07:57 AM
Dogman
Dogman's Avatar
That's the hardest part of the install. I use a flat-head screwdriver to help push the plastic tabs in. Let it sit out in the sun for about an hour to loosen up a bit.
John 3:17
Dogman is offline
post #6 of 13 Old 12-24-2009, 08:26 AM
j_bydesign
Wrench Wheel Repeat
j_bydesign's Avatar
Mine was hard at first(the top that is!) but after a couple of days in the sun it was alot easier... but mine is rarely off... the blazing South FL sun is a bit to much on the top of my noggin! live in the NE for most of my life... do not miss the snow...and have not had the doors on in weeks! Merry Christmas!
'04 TJ(wheeler) '65 CJ5(sold :( )...'05 LJ(Scrambler conversion, SOLD!) 89' Int. Harvester Toter (SOLD)! '80 CJ7 Resto Mod(sold) 1985 CJ7 Renegade (in process/million pieces) 2000Kenworth Hauler
j_bydesign is offline
post #7 of 13 Old 12-24-2009, 02:26 PM
Wloch248
I have a factory mopar bikini top that I haven't been able to strech all the way across either. I am going to trim just a hair off the surrounds when it gets warmer.
Wloch248 is offline
post #8 of 13 Old 12-24-2009, 04:56 PM
Bishop Creek
Really? I have no problem with my Mopar bikini top. Do you let it sit in the sun for a while first?
post #9 of 13 Old 12-24-2009, 05:23 PM Thread Starter
scrnnmssuck
hey is there a difference in tops with wise between the newer tj. I have a 97 and the top was bought used off craigslist. Is it possible the 03+ tj's have a narrower top then my 97 would have.
post #10 of 13 Old 12-24-2009, 06:40 PM
Dmoriarty
This worked for me - start at the front corner on either the passenger or driver side(doesn't matter which), dont put it in more than half way, go to the other side and put the back corner in and get it to go as far as you can. Then go to the original side and finish. It helps to have someone hold the first corner in when you go to do the other side.
05 Rocky Mountain
Dmoriarty is offline
post #11 of 13 Old 12-24-2009, 07:26 PM
Wloch248
I just got it while it was a little cold this fall and it hasn't been warm or sunny enough since.
I tried to do one side partially then the other side and it wasn't even close.
I would rip/break it if I tried to use vice grips and it isn't even nearly close enough for me to do anything with a screwdriver.
Wloch248 is offline
post #12 of 13 Old 12-24-2009, 07:54 PM
2005X
nope. otherwise my 2001 softop would be to tight to fit on my 05
2005X is offline
post #13 of 13 Old 12-25-2009, 12:09 AM
bige2533
The tops are made from denim. They will stretch a little after being installed and they are a lot easier to put on when it is hot outside.
bige2533 is offline
Bikini Does Not fit w/ Door Surrounds SuperWade2 TJ Wrangler Technical Forum 16 05-18-2007 12:31 PM
bikini top without using door surrounds??? 4wheel4real TJ Wrangler Technical Forum 24 10-16-2006 09:40 AM
Bikini Top + Door Surrounds = Frustration LoneJeeper TJ Wrangler Technical Forum 12 04-12-2006 01:50 PM
is there a bikini that utilizes the oem door surrounds? under_psi TJ Wrangler Technical Forum 7 04-09-2005 05:16 PM
bikini and door surrounds question motox851 TJ Wrangler Technical Forum 7 03-29-2003 08:16 PM
