Ya thanks I was refering to a link to which top to buy...anyway you say you can use it with or without the door surround, so it comes with straps correct?
Correct, it comes with everything you need aside from the header channel piece. The whole setup fits real well without the door surrounds but WITH the surrounds it's tight as a drum.
I got a bikini top off ebay. Has the velco straps and can be used w/ or w/o the door surrounds
Second picture is not all that great. But you can use with both. I also have a ebay tonno cover and a best top wind jammer. All three are made good and have had no problems with any of them. Would reccomend both Best Top or Ebay one (I believe outland)
I actually have one that is a JEEP one (Mopar) that I want to sell. Basically, it is for a hard top, meaning it does not mount to door surrounds, but rather it has the velcro to go around the rollbar. It actually goes over the speaker bars too. I know wrong spot in forum, but if anyone is interested in it, PM.
Guy do ya think wrnglrguy's bikini top off his 04 tj would fit my 98 tj? Its designed to fit the speaker bar and we arnt sure if the 04 and 98 tj speaker bars are the same????
Do like I did. Take your door surrounds off and remove the C-clip that holds the upers to the lopwers on.
Place the uppers back on
Install bikini
No more lowers until you need to put your soft top back on. As well the bikin fits better with the uppers on. Check out my write-ups in my sig for photos.
Yep... I've got an extra set of door surrounds specifically for that reason :thumbsup:
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
