Biggest tires can put on stock 06 se w/stock rims? - JeepForum.com
post #1 of 5 Old 04-28-2007, 11:01 AM Thread Starter
thebatmobile
What's the biggest Tires I can Put on my 2006 Wrangler se with Stock rims. I see super Swamper LTB has a 31X11.5X15 can I use these or can I go bigger?
Ron
Thomas, Pa to Tallmadge, Oh
Thank you for your support
thebatmobile is offline
post #2 of 5 Old 04-28-2007, 11:04 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
31x10.50x15 is the biggest for an unlifted TJ. 11.50" wide tires are generally a bit too wide in that their inside sidewall can rub in the rear if mounted on factory wheels that have a bit too much backspacing for a tire that wide.
Jerry Bransford is offline
post #3 of 5 Old 04-28-2007, 12:19 PM
airframer
airframer's Avatar
i have an 05 tj with 15x8 rims and i run 33x12.5 xterrrains, but i also have a 3.5 re lift, as far as your with goes hes rite ull rub, i got wheelspacers to fit mine on
airframer is offline
post #4 of 5 Old 04-28-2007, 12:44 PM
[ITA]Tsunami
Italian Wheeler in Mexico
[ITA]Tsunami's Avatar
What's your point here? the OP have a stock TJ with stock wheels. To the OP, 31x10.50 it's the bigger you can go stock without rubbing around. Same size as the stock MTR rubis come with.
Originally Posted by mdm
However it is a strange twist in the cosmic thread that will not allow the driver of a Jeep that has experienced air bag deployment off-road to consume beef for 48 hours after the event. You can consume chicken, pork, turkey, or emu.
[ITA]Tsunami is offline
post #5 of 5 Old 04-29-2007, 11:34 AM Thread Starter
thebatmobile
thanks all
Ron
Upgrade stock tires/rims with larger stock tires/rims (08 Wrangler Unlimited)QUESTION makstuss JK Wrangler Technical Forum 3 02-20-2011 04:23 PM
Biggest tires on stock rims? 92jeepyj YJ Wrangler Technical Forum 5 02-14-2008 05:52 AM
biggest tires on stock rims drm822 TJ Wrangler Technical Forum 5 02-28-2007 10:01 AM
Biggest tires on stock 05 SE TAliyev TJ Wrangler Technical Forum 10 04-24-2005 05:15 PM
biggest tires on a stock 88 YJ Willie YJ Wrangler Technical Forum 12 08-27-2002 07:08 AM
