biggest tire w/o scrub. - JeepForum.com
post #1 of 12 Old 11-30-2011, 10:37 PM Thread Starter
ofcrtj
So I just bought an 03 tj x and am considering upgrading to an off road tire. My question is what's the largest tire I can put on with out it scrubbing rubing or being dangerous?
ofcrtj is offline
post #2 of 12 Old 11-30-2011, 10:52 PM
abobaen
did you even think about using the search bar, it is at the top left corner of every page on the forum. not trying to be mean or anything, but your question has already been answered, many times and i see this question posted every time i log on
and remember this is fix only temporary,... unless it works
Originally Posted by YouStupidBunny View Post
I'm too old to play with Lego's, so I got a Jeep.
abobaen is offline
post #3 of 12 Old 11-30-2011, 10:59 PM Thread Starter
ofcrtj
Using the app on my phone, the built in search engine does not work so well. Do you have a link to these previously answered forums?
ofcrtj is offline
post #4 of 12 Old 11-30-2011, 11:00 PM
threeb
This information was found in the TJ sticky.
08-08-2007, 11:03 PM #1
Wheelin98TJ
JEEP FREAK
Profile
Gallery
Classifieds
My Jeeps
iTrader Rating
FAQ - What size tires can I fit on my TJ?
Height
The tire height you can use on your TJ without rubbing is determined by lift height, bumpstop length, and other body modifications such as trimming, high-clearance fenders, etc.
The chart below is intended to be used as a guide only for TJs with stock, untrimmed body parts. Different tire brands and different suspension lift brands will typically vary in actual height. You will need longer bumpstops to prevent tire rub if using tires 31" or larger tires off-road.
08-08-2007, 11:06 PM #2
Wheelin98TJ
JEEP FREAK
Profile
Gallery
Classifieds
My Jeeps
iTrader Rating
Width
The tire width you can use on your TJ is determined by the backspacing of the wheel. Stock TJ wheels have backspacing ranging from 5"-5.5". A list of stock TJ wheel specifications including backspacing can be found HERE
The chart below is intended to be used as a guide only. Different tire brands will vary in actual width. You may have slight rubbing when turning full lock if you are running the MAXIMUM suggestion below.
LJ Owners Group member #431.
threeb is offline
post #5 of 12 Old 12-01-2011, 06:48 AM
Jason
Those tables didn't copy over to the post.
Here's the link: http://www.jeepforum.com/forum/f9/fa...-my-tj-447831/
Jason is offline
post #6 of 12 Old 12-01-2011, 07:59 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
31x10.50".
TheBoogieman is offline
post #7 of 12 Old 12-01-2011, 08:41 AM Thread Starter
ofcrtj
Thanks big help. But 31 the height of tire 15.5 is the height of the rim and 10.5 is the width of both???
ofcrtj is offline
post #8 of 12 Old 12-01-2011, 08:47 AM
klincker
31x10.50 is the tire height and width. your rims are probably something like 15x7 or 15x8 the tire will then read 31x10.50x15
2013 JKU Sport S 6speed
99 TJ sahara 5spd--sold
94 YJ 4cyl 5spd--sold
klincker is offline
post #9 of 12 Old 12-01-2011, 09:00 AM
TheBoogieman
Disturbed
31x10.50x15= 31" tall/10.5" wide/15" wheel.
post #10 of 12 Old 12-01-2011, 09:16 AM Thread Starter
ofcrtj
copy, anyone have experience wit treadwrights?
ofcrtj is offline
post #11 of 12 Old 12-01-2011, 09:34 AM
threeb
Shipping is about a 120$ and the tires are 95$ apiece then 50 to mount and balance. You can't get 4 carcasses the same they are paired. So at about $640 bucks it's not that great of a deal.
threeb is offline
post #12 of 12 Old 12-01-2011, 10:21 AM Thread Starter
ofcrtj
so about the same as a set of bfgs at the local shop?
ofcrtj is offline
