bigger tires bigger brakes? - JeepForum.com
post #1 of 8 Old 10-25-2009, 02:34 PM Thread Starter
APEDZ04LJ
If i upgrade from my 31 bfg ats to 33 bfg at's other than gearing will i need bigger brakes?
APEDZ04LJ is offline
post #2 of 8 Old 10-25-2009, 02:56 PM
JBTJ
No, I wouldn't think so. But, if you went above 33's you will.
JBTJ is offline
post #3 of 8 Old 10-25-2009, 02:58 PM
RogueSpear2023
33s are the really the cut off point, for not needing bigger brakes. If you need to replace the brakes I would look at some centic rotors, and EBC yellow stuff brake pads though.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #4 of 8 Old 10-25-2009, 03:00 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
It depends on your Jeep.I upgraded to Centric rotors and EBC yellowstuff pads and they were much better than stock.My 33's were fine on stock brakes.My 98' sucked with 35's and stock brakes and my 03' brakes work fine with 35's.It's all up to you and how your Jeep works.
TheBoogieman is offline
post #5 of 8 Old 10-25-2009, 03:04 PM
tulman22
I run 35s on my stock brakes and they are working fine.
Will be upgrading once I do need a brake job though.
US Navy "SPOOK" RETIRED
Impact Orange member # 39
tulman22 is offline
post #6 of 8 Old 10-25-2009, 03:37 PM Thread Starter
APEDZ04LJ
my rotors and pads are shot so im trying to figure out if i can knock on bigger brakes a 1" bl on top of my rc 2.5 and 33 bfg ats on soft 8's and the jks mml and jks discos
post #7 of 8 Old 10-25-2009, 05:34 PM
RubiconRazorbac
RubiconRazorbac's Avatar
If you're replacing them anyway, get the Centric Premium rotors and EBC yellowstuff pads as recommended by Boogie. With 33s you're probably "OK" without the upgrade, but if you get the upgrade you won't be sorry.
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #8 of 8 Old 10-25-2009, 05:57 PM
ImNotStuck
When going from stock to 33's there was one hell of a difference in stopping time. They worked fine for easy driving but if you have to stop fast you will notice the extra 30 feet it takes to stop
Originally Posted by BIGRED99 View Post
I really have nothing in common with majority of you losers to be honest with you, is there an avator in here??? I would love to be deleted from Jeepforum as I drive an Audi now. Thank you and goodbye...
ImNotStuck is offline
Bigger Lift means Bigger Problems?? Jeep Kid TJ Wrangler Technical Forum 1 03-08-2008 03:41 PM
Bigger Brakes jmreagan TJ Wrangler Technical Forum 16 06-13-2006 01:40 PM
Bigger Tires = Need for Better Brakes?? DirtDemon TJ Wrangler Technical Forum 12 02-16-2006 04:00 PM
Bigger tires= need for better brakes. Need help! Unlimited77 TJ Wrangler Technical Forum 11 09-30-2005 04:17 PM
Anti-lock brakes and bigger tires Fargo TJ Wrangler Technical Forum 3 05-26-2005 08:21 PM
