Bigger Lift means Bigger Problems?? - JeepForum.com
post #1 of 2 Old 03-08-2008, 04:21 PM Thread Starter
Jeep Kid
I am thinking about adding 4 adjustable coil spacers to my 98' TJ. My Jeep doesn't sit level with the 4'' lift on it now, and I recently added a 400lb bumer/tire carrier to the rear, so its going to sag sooner or later. The ACS add a minimum of 1 1/4'' of lift, but I would probably adjust them to 2'' give or take a little. My question is, going with total of 6'' of lift, am I going to have any problems with my drive train or 4WL kicking in/out?? I'm not sure how much lift I can go with stock drivetrain set up. I know with the larger lifts (6"+) you need a slip-yoke eleminator or something. I just want to level my Jeep out without too many complications. Thanks!
Jeep Kid is offline
post #2 of 2 Old 03-08-2008, 04:41 PM
daveg13
daveg13's Avatar
4"+ you're gonna need a sye.
'99 Sport
31X10.5-15 BFG AT, some Tuffy boxes, slowly being built.
daveg13 is offline
bigger tires bigger brakes? APEDZ04LJ TJ Wrangler Technical Forum 7 10-25-2009 06:57 PM
who has had a lift w/bigger tires and no esp problems? rondawg JK Wrangler Technical Forum 8 05-07-2007 10:47 AM
bigger tires on spare problems HELP!? seany425 TJ Wrangler Technical Forum 4 03-20-2004 09:38 PM
Bigger wheels, Bigger problems??? mudstuck TJ Wrangler Technical Forum 9 09-28-2003 11:03 PM
Bigger tires means better axles/trans 4x4 Ranger YJ Wrangler Technical Forum 4 05-29-2003 01:28 PM
