Bigger brakes... - JeepForum.com
post #1 of 18 Old 05-31-2007, 10:09 PM Thread Starter
lj_wil
ekorb mi
lj_wil's Avatar
Bigger brakes...
Looking at the Vanco brakes, why only the front disks?
I'm thinking to really update your brakes you would need all 4 disks, a stronger pump and probably thicker brake lines.
What have you done to upgrade your brakes?
W6FU
lj_wil is offline
post #2 of 18 Old 05-31-2007, 10:30 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Because when you get to the point where you start thinking about better brakes, it's usually because your OEM brakes are failing due to a higher center of gravity and bigger rotational masses of larger tires.
So you have a two fold issue to solve in that the larger heavier tires are harder to slow down and the weight transfer to the front brakes really brings out all of the deficiencies they have.
That means your front brakes are now being asked to do work they were never designed for and they perform poorly at best.
Properly maintained and adjusted, there is nothing wrong with rear drum brakes other than difficulties in adjustment and maintenance. They do fade easier, but only at the extreme end of day to day braking scenarios.
a stronger pump
There is no pump in the TJ that affects braking performance other than the ABS pump and no one really knows how to upgrade or mess with that, not that it would make any difference.
However, the TJ does come from the factory with a very fine and high quality dual diaphragm booster and master cylinder. Combined with good brakes they are very capable of locking up 37's easily with no other modifications to anything.
Thicker brake lines if you are referring to the diameter do nothing for you. In the testing I've done, not even stainless steel braided line outperform the OEM lines if they are functional.
Personally, I've done every brake mod known to man practically. Outside of some little gadget I saw once that bolted onto the master cylinder, I've done just about everything else.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #3 of 18 Old 05-31-2007, 10:33 PM
bman9089
bman9089's Avatar
good post mrblaine.
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain
Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38
bman9089 is offline
post #4 of 18 Old 05-31-2007, 10:38 PM Thread Starter
lj_wil
ekorb mi
lj_wil's Avatar
Great information, but I would not expect less coming from the horses mouth
So upgrading the front disks alone is reasonable for running 35's, with no other upgrades? Out of curiosity, will these same rotors fit on the rear disks as well?
Thanks again!
W6FU
lj_wil is offline
post #5 of 18 Old 06-01-2007, 12:25 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Thanks again!
You've confused me. Upgrading the front discs is not what Vanco does.
I am Savvy
post #6 of 18 Old 06-01-2007, 08:19 AM Thread Starter
lj_wil
ekorb mi
lj_wil's Avatar
Sorry for the confusion, it's obvious that I'm not clear on quite a few things.
So, looking at this kit:
http://northridge4x4.com/proddetail....=VANCO-DISCKIT
It appears that the rotors, knuckles and pads are "bigger" and that this is a front brake kit. You've stated previously that upgrading to thicker lines don't really do anything, and that the OEM mastercylinder and booster are reasonable. You've done the testing so I am sold on all of this.
For those of us that have disc's all around, is it worth upgrading the same parts on the rear? Is a rear kit available? And if so, would that change any of the above?
W6FU
lj_wil is offline
post #7 of 18 Old 06-01-2007, 08:59 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The rotors, and calipers are bigger, it is a front brake kit, but the knuckle is OEM and has just been changed slightly to accept the adapter plates for the caliper.
They booster and master is more than reasonable. It is capable of driving much larger systems than Van's small kit.
In all of the installs I"ve done, I've not seen the need to do anything to the rear brakes yet. I say yet because Van never quits improving stuff. I have started to notice that as the fronts start working better and better, there seems to be a small need to dial out some rear brake and adjust the bias on the taller rigs. The weight transfer is getting high enough with the better front braking that the rears are starting to lock up.
I am Savvy
post #8 of 18 Old 06-01-2007, 09:27 AM
TJeeper
TJeeper's Avatar
The information you are missing is ~90% of the stopping power is done by the front brakes in a hard stop. This has to do with weight transfer. As long as your rear brakes are properly adjusted and not locking up, then they are working fine. Think of it this way, they work like an anchor, keeping the vehicle straight in a hard stop. Lock them up and you have lost the anchor, allowing the vehicle to slide around in a dangerous situation.
Patrick
TJeeper is offline
post #9 of 18 Old 06-01-2007, 10:15 AM Thread Starter
lj_wil
ekorb mi
lj_wil's Avatar
Thanks for the very useful information, I will be jumping on board in a few weeks
W6FU
lj_wil is offline
post #10 of 18 Old 06-01-2007, 10:17 AM
Deezul
Deezul's Avatar
wow that Vanco kit is $$$$$$
2004 Khaki Rubicon. Jeeperman Custom Brushguard and 54" bumper, Kilby steering skid, Skidrow radiator skid, SRC Rockcrawler rocker guards, UFW Al Engine Skid, OME Shocks, JKS Quicker Discos, AEM Dryflo intake;KC Slimlight 130W Long range lights, ORO LiteDots and LitePlate, Banks Stainless Monster cat-back, Eclipse stereo, BA Speakers, Jeeperman Handles, Cobra CB, interior leds... more to come.
**R.I.P NOW TOTALED** 98TJ Sport, 30x9.5 BFG ATKO's on AR Outlaw II's, K&N FIPK, Borla Catback,
Green jeep club member #139
Deezul is offline
post #11 of 18 Old 06-01-2007, 11:12 AM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
Worth every penny IMO. When I put my foot down, my passenger becomes one with the windshield
I'll be Savvy someday!
neZZr is offline
post #12 of 18 Old 06-01-2007, 11:40 AM
TJeeper
TJeeper's Avatar
_________
2004 Khaki Rubicon. Jeeperman Custom Brushguard and 54" bumper, Kilby steering skid, Skidrow radiator skid, SRC Rockcrawler rocker guards, OME Shocks, BDS Ultimate Discos, AEM Dryflo Bruteforce intake;KC Slimlight 130W Long range lights, ORO LiteDots and LitePlate, Banks Stainless Monster cat-back, Alpine stereo, BA Speakers, Jeeperman Handles, Cobra CB,... more to come.
Everyone has their priorities. Yours seems to be to have a loud Jeep. Mine is to stop.
Patrick
TJeeper is offline
post #13 of 18 Old 06-01-2007, 01:32 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You need to go price some of the other bigger brake kits or even rear disc brake conversions.
Once you do that, you'll be able to figure out pretty quickly that Van's prices are about the best value going in that regard.
SSBC's rear disc conversion is over a grand and the only other front conversion I've seen is over 1500.
I am Savvy
post #14 of 18 Old 06-01-2007, 01:36 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I just did a quick search for Baer. Their economy kit for an Eclipse which includes calipers, rotors and lines is over a 1000 bucks on sale.
I am Savvy
post #15 of 18 Old 06-01-2007, 02:39 PM
jeepster93
jeepster93's Avatar
I did rear discs, not for hiway as much as for on trail.
I think discs are a sweet trail upgrade.
Sitting on a steep hill where the wieght on the rear brakes, discs are better than drums. Then there is the "waterproof" aspect of discs, where drums need drying out first.
jeepster93 is offline
bigger tires bigger brakes? APEDZ04LJ TJ Wrangler Technical Forum 7 10-25-2009 05:57 PM
Bigger brakes in Kit Form? mrblaine TJ Wrangler Technical Forum 61 06-13-2006 01:48 PM
Bigger Brakes jmreagan TJ Wrangler Technical Forum 16 06-13-2006 01:40 PM
Bigger Brakes TJ Unlimited TJ Wrangler Technical Forum 3 05-23-2006 08:29 AM
Bigger tires= need for better brakes. Need help! Unlimited77 TJ Wrangler Technical Forum 11 09-30-2005 04:17 PM
