Big Tire - flex vs Small Tire + flex - JeepForum.com
post #1 of 5 Old 05-02-2010, 04:30 PM Thread Starter
rkwfxd
So, in general, what do you think is better, a larger tire which creates more ground clearance under the axles but with limited flex due to longer bump stops to keep it from rubbing or a smaller tire which gives up some ground clearance but can flex much more?
rkwfxd is offline
post #2 of 5 Old 05-02-2010, 04:33 PM
gus54
IMO - neither. I would say a bigger tire and then create the room for it with flat fender flares, tube fenders, trimmed flares, whatever to get required flex.
gus54 is offline
post #3 of 5 Old 05-02-2010, 04:36 PM
hulud44
Big rubber + LCG
Currently under heavy construction…..
NYC Jeep Club
hulud44 is offline
post #4 of 5 Old 05-02-2010, 04:42 PM
TEEEJ
Bumpstop extensions are evil uptravel robbing mods that should be avoided if possible.
Removal/modification of the fenders, or at least a BL to get them up out of the way, etc...are preferable to losing uptravel.
Depending upon the terrain you wheel on, the ground clearance, and/or flotation of bigger meats is typically valuable enough to make sacrifices to get.
If you lose uptravel, it means the truck rises with the terrain, instead of the truck staying level, and the tires going up/down by them selves.
In off camber and/or uneven terrain, this can lead to less stable positions, a bad thing.
So, you want the uptravel, and you want the ground clearance.
If you are a flat lander, and your articulation is limited to mud, you might bias your choices in that direction...if you do rocks/rough terrain, you might bias it in THAT direction, etc.
TEEEJ is offline
post #5 of 5 Old 05-02-2010, 04:57 PM
never monday
(but, it depends on what the plan is)
never monday is offline
More flex? Ronnie-Evans YJ Wrangler Technical Forum 29 04-22-2010 08:45 PM
confused...bout tire size fitting with 33 and small lift bcameron1974 YJ Wrangler Technical Forum 10 05-13-2009 09:48 PM
Tera Flex Rear tire carrier REDPILL TJ Wrangler Technical Forum 3 04-14-2009 12:57 PM
Max. Flex vs. Useful Flex and The Anti-rock lupinsea TJ Wrangler Technical Forum 34 10-29-2008 10:03 AM
RE Super flex or Standard flex treypal TJ Wrangler Technical Forum 10 06-21-2005 08:01 PM
