-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Big Tire - flex vs Small Tire + flex (http://www.jeepforum.com/forum/f9/big-tire-flex-vs-small-tire-flex-1024472/)
rkwfxd 05-02-2010 04:30 PM
So, in general, what do you think is better, a larger tire which creates more ground clearance under the axles but with limited flex due to longer bump stops to keep it from rubbing or a smaller tire which gives up some ground clearance but can flex much more?
gus54 05-02-2010 04:33 PM
IMO - neither. I would say a bigger tire and then create the room for it with flat fender flares, tube fenders, trimmed flares, whatever to get required flex.
hulud44 05-02-2010 04:36 PM
Big rubber + LCG
TEEEJ 05-02-2010 04:42 PM
Bumpstop extensions are evil uptravel robbing mods that should be avoided if possible.
:D
Removal/modification of the fenders, or at least a BL to get them up out of the way, etc...are preferable to losing uptravel.
Depending upon the terrain you wheel on, the ground clearance, and/or flotation of bigger meats is typically valuable enough to make sacrifices to get.
If you lose uptravel, it means the truck rises with the terrain, instead of the truck staying level, and the tires going up/down by them selves.
In off camber and/or uneven terrain, this can lead to less stable positions, a bad thing.
So, you want the uptravel, and you want the ground clearance.
If you are a flat lander, and your articulation is limited to mud, you might bias your choices in that direction...if you do rocks/rough terrain, you might bias it in THAT direction, etc.
:D
never monday 05-02-2010 04:57 PM
:D
:D
:eek: :rolleyes: (but, it depends on what the plan is)
The time now is 01:46 AM.
