Big Problem. Need help. - JeepForum.com
post #1 of 7 Old 03-29-2012, 11:44 AM Thread Starter
nirakenna
We live 9 miles into a jungle and need our wrangler. We took to town to have the engine cleaned. It did not run right after this so we took it back. The mechanic took the battery cable off the battery and when he put it back, the alarm went off. He did not have the remote and he could not find the shut off switch, so he cut the alarm system out of the car. Now we cannot start the car. We contacted the alarm installer in the states and he gave us some guidance but suggested that there may be a different problem other than the alarm. Someone suggersted that the computer might be bad. Any help, greatly appreciated.
nirakenna is offline
post #2 of 7 Old 03-29-2012, 12:00 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Please give details of your Jeep for better answers.Alarm system,engine,year,etc.
(Read the profile age before being mean JF people)
TheBoogieman is offline
post #3 of 7 Old 03-30-2012, 11:49 AM Thread Starter
nirakenna
The alarm was a prestige. We have no interest in hooking it back up. We just want to get jeep started so we can use it. It is a 2006 Wrangler 2.2 liter. The diagnostic computer does not read the computer in the jeep.
post #4 of 7 Old 03-30-2012, 11:54 AM
STIFLER
um how was the engine "cleaned"
0311/2531 USMC YUT
STIFLER is offline
post #5 of 7 Old 03-30-2012, 12:00 PM
DezertTJ
It must have a kill switch and now the switch may not work? My tj had that. Look under the steering collumn and see if the alarm is spliced into the inginition wires. I had to cut those and remove the entire alarm. Started right up after that
DezertTJ is offline
post #6 of 7 Old 03-30-2012, 12:15 PM
JustinCHorst
What he said....check under the steering collum and remove the alarm, I am sure that is your only problem....also would it have not been easier for the mechanic to disconnect the battery? Thank boy genius for your troubles...best of luck!
JustinCHorst is offline
post #7 of 7 Old 03-31-2012, 07:41 PM Thread Starter
nirakenna
It was powerwashed.
96 , alarm , computer , tj , wrangler
clutch problem ? Master / Slave Cylinder Problem rthompson48082 YJ Wrangler Technical Forum 34 11-30-2011 05:31 PM
Belt problem, blinker problem, and a random problem... Mike89db TJ Wrangler Technical Forum 10 12-14-2009 05:34 AM
brake pad problem, and front drive shaft problem bluejeep2088 TJ Wrangler Technical Forum 1 05-12-2008 09:34 AM
Brake Fluid problem or Jeep Drinking problem daledaniel TJ Wrangler Technical Forum 6 01-04-2008 09:11 PM
FINALLY! fixed idle problem and stalling problem Big-n-Broke-YJ YJ Wrangler Technical Forum 4 02-28-2006 07:50 PM
