Big 3 (Battery cabling upgrade - custom) - JeepForum.com
post #1 of 169 Old 02-05-2013, 08:03 PM Thread Starter
fourwheelin
Didn't want to resurface or hijack someone's thread, but thought some would appreciate this write-up on how to replace/upgrade all the battery cables in a TJ. Lots of pics!
http://daedalusideas.blogspot.com/20...3-jeep-tj.html
fourwheelin is offline
post #2 of 169 Old 02-05-2013, 08:31 PM
BYuen
BYuen's Avatar
Great writeup, thanks! Bookmarked it. I will definitely use this whenever I get around to upgrading my wires for a higher amp alternator.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #3 of 169 Old 02-05-2013, 08:35 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
A couple of things to note-
He didn't crimp them deep enough for some reason. That tool is designed to be smacked with a hammer, do so.
On the alternator picture, that is a very poor way to route a soldered connection of that size. The solder wicks down into the strands and creates a stress riser that will break under vibration. He would have done better with it pointing down to relieve some of the load.
If you are going to use split loom in an engine compartment, get the black stuff with the white stripe, it is rated for higher temps that get in the engine bay.
Other than that, he did a good job and if he remembers to turn the terminals square on the battery when he puts the new one it, all will be good.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #4 of 169 Old 02-05-2013, 08:58 PM
snookhansel
I prefer to use a crimping tool. Crimping the wire too much is equally as bad as not enough crimp. Crimping tools either auto release pressure when the correct pressure is met or mechanically limit themselves like a hex or round die does. These factors also rely on the type or brand lugs you use. Of course I know you know this Blaine and I'm sure for the load this cable will see no one really needs to be this anal about their cramping methods. For most it would not be worth the cost of the correct tool. I own several different types and they are not cheap.
snookhansel is offline
post #5 of 169 Old 02-05-2013, 09:04 PM
77351wcj5
Everyone has their own style, some more cramped than others.
77351wcj5 is offline
post #6 of 169 Old 02-05-2013, 09:12 PM Thread Starter
fourwheelin
I didn't have a surface to smack the tool on. But realized while crimping I didn't need to as (1) the c-clamp squeezed enough where I couldn't pull the cable out of the lug even with all my might. (2) Once it was soldered, it was like a solid piece of metal - no way its coming apart. But good point for others to know/think about.
As for the alternator connection, I'll take the advice and turn it down a bit. I just mirrored the stock connection. But like I just mentioned, the solder made it solid where it has no flex, so not too worried. I had it on like this for a month now and even had it out wheelin' - no issues so far!
What's that about squaring the terminals with the battery? Just for looks? Actually, due to the larger cables I made, I had to turn the negative a bit in order to allow the cable not to touch or rub anything running up to the body.
Thanks for the input.
Glad it can help. I plan on updating it once I get the new battery in. So syked about it. Cause I got an awesome deal, but mainly cause its spill proof!
post #7 of 169 Old 02-05-2013, 09:40 PM
snookhansel
Yeah I caught that after I posted. I post from my phone and sometimes it spells for me and I don't catch it. Also I agree with Blaine. I would have never soldered the crimp. If you make a good crimp there is no need. Although a dimple crimp may be UL approved on aluminum lugs I'm just not a fan. But copper lugs aren't as pretty. Oxguard in aluminum or copper clad aluminum to aluminum wire is always a really good idea. This is just me being very anal though. All in all you did a fine job.
post #8 of 169 Old 02-05-2013, 10:06 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You make cables for the life of the vehicle, a month is nothing in the lifespan. The issue with soldering cable is the solder wicks down into the strands and makes it solid with no flex. If we could make that work, there would be no reason for stranded wire, we would just use solid.
At the hard spot transition, there is no strain relief if the solder has wicked too far into the strands and continual vibration will start causing the strands to break at the end of the solder.
If you are going to do it that way, find the hard spot and continue that Triple wall adhesive lined heat shrink you used past it a ways to build in some strain relief.
I didn't think I left this guy out did I? That means my normal OCD is kicking in about things being symmetrical and lined up.
I like the batteries I like, but if asked, I tell everyone to get what ever does not spill. There is more damage done to vehicles from corrosion and acid than should be legal. If you can't mount it on it's side, it don't belong in a Jeep.
I am Savvy
mrblaine is offline
post #9 of 169 Old 02-05-2013, 10:09 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I don't solder anything electrical for the most part. I have a swaging tool for cable size terminals and enough crimpers for the rest to make your eyes water if you had to buy them all at once.
The bad part of that is I'm considering moving away from Weatherpak and going to Deutsche and not looking forward to that learning curve or the tool buying curve.
I am Savvy
mrblaine is offline
post #10 of 169 Old 02-05-2013, 10:23 PM
snookhansel
I'm all about burndy and Greenlee. Its most of what I own has been.around forever and a day. It is time tested and proven. I have never had hydraulic issues with greenlee. Their dies crimp sweet. Like I said I prefer a round squeeze crimp. I do also own a couple of dimple crimpers but they crimp in 4 spots around the barrel and release at a predetermined pressure. These type of crimps can be bad if a person isn't using a quality lug.
post #11 of 169 Old 02-05-2013, 11:18 PM
5-90
5-90's Avatar
1988 XJ Cherokee
I've done Weatherpacks for years - are Detsche really that different? I haven't torn any to bits...
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #12 of 169 Old 02-06-2013, 07:05 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Deutsche are smaller, seemingly more robust, cleaner looking, and what is used by all the folks that do high end wiring on the desert race stuff.
It's also the connector used on Rigid light bars.
I am Savvy
mrblaine is offline
post #13 of 169 Old 02-06-2013, 07:14 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Quality is what it's all about when it comes to wiring, tools, and terminals. I use the high end terminals that have the double crimp that gets the wire and the insulation for strain relief. I have the matching crimper.
http://www.delcity.net/store/Nylon!i...inals/p_802012
I also use tinned copper boat cable and wire for the vast majority of my wiring.
I am Savvy
mrblaine is offline
post #14 of 169 Old 02-06-2013, 05:19 PM Thread Starter
fourwheelin
Thanks. First time doing this work. If I ever do it again (hopefully not on this vehicle), looks like I have some pointers to consider from you guys.
post #15 of 169 Old 02-06-2013, 07:57 PM
Icarus
Looks like fun
I'm having Jeepersandcreepers make up a set for me and some extra cables for my aux fuse panel. They look to do great work, and are super helpful.
Ϣr
Icarus is offline
battery , big , cable , wires , wiring
